Etching and ground planes
Results 1 to 7 of 7
    Ground plane are nice for various things. However they also have their culprits. You may do a little search and sure enough you will find some documentation on how to implement them the right way (assuming the author know how to )
    You want to avoid unconnected islands, those may give you strange results and maybe screw up your whole design.
    Take a bit of your time to read those bellow.
    http://www.ce-mag.com/ce-mag.com/arc...103CE_028.html
    http://www.radioing.com/eengineer/pcb-tips.html
    http://www.amd.com/files/connectivit...86cc/22507.pdf
    HTH
    Jan 2008
    Pennsylvania
    Default Good advice from all.
    I appreciate everyones advice. Thanks for the links Mr. E very helpful reading.
    Thanks again
    David
  1. GROUND plane or nor GROUND plane
    Last Post: - 11th November 2008, 18:19
