can i splice the other pics onto the tx/rx lines after the max 232?
no max 232 will not support multipoint *kinda network* IMO. if you want to do something like that you will need to use RS485/RS422 drivers like MAX485 or else who support multipoint. OR add another Max232 on the same PIC tx/rx pin. For the RX you'll need diode mixer or something like that to avoid short between signals.
But you can test with MAX232. TX could be tie together, RX... diode mixer with pull down. Could work on some case!!
