Interruptus Frustratus
Results 1 to 17 of 17
    Miami, Florida USA
    Thank you Darrel. That solves part of my problems in this project I'm working on.
    Miami, Florida USA
    Attached is some of my code (without all the other stuff that nobody cares about) of the Capacitive Sensing Module (CSM) that I'm working on. My project is similar to Byte_Butcher's but I'm only using PBP. There is still some work to be done like having some arrays would be nice, but so far the touch pads work fine.
    '*         DEFINING VARIABLES AND SETTING INITIAL VALUES        *
    DEFINE OSC          4       	    'Define Oscillator to 4MHz
    I               VAR WORD
    TRIP            VAR BYTE
    STABILIZE_CSM   VAR BYTE            'VARIABLE USED TO LET MCU STABILIZE CSM
    BUTTON          VAR BIT
    START_PROGRAM   VAR BIT             'ONLY USED AT START OF PROGRAM (=0 NO BUTTONS TOUCHED YET)
    RAW_0           VAR WORD
    RAW_1           VAR WORD
    AVERAGE_0       VAR WORD
    AVERAGE_1       VAR WORD
    LED_0           VAR PORTB.6
    LED_1           VAR PORTB.7
    TEST_VAR        VAR BYTE
    STABILIZE_CSM = 2                   'LET CSM RUN 2 TIMES BEFORE TAKING READINGS
    TRIP = 50                           'TRIP USED AS (1/50)*(AVERAGE)
    LED_0 = 0                           'LEFT BUTTON LED
    LED_1 = 0                           'RIGHT BUTTON LED
    RAW_0 = 0
    RAW_1 = 0
    AVERAGE_0 = 0
    AVERAGE_1 = 0
    BUTTON = 0                          'START WITH BUTTON 0 (LEFT)
    TEST_VAR = 0
    '*         CAPACITIVE SENSING MODULE INITIALIZATION             *
    TRISA = %00000000           'Initialize ports as outputs
    ANSELA = %00000000          'Initialize as digital ports
    TRISB = %00010001           'Initialize PortB.0 and PortB.4 as inputs.
    ANSELB = %00010001          'Initialize CPS4 and CPS0 as analog inputs.
    TRISD = %00000000           'INITIALIZE ALL PORTS AS OUTPUTS
    ANSELD = %00000000          'INITIALIZE ALL PORTS AS DIGITAL PORTS
    TRISC = %10000000           'INITIALIZE RC7 AS INPUT (SERIAL RX)
    CPSCON0 = %10001111         'CAPACITIVE SENSING MODULE IS ON. OSCILLATOR IS IN HIGH RANGE.
    CPSCON1 = %00000000         'BITS 3-0, 0000= RB0/CPS0 IS THE CAPACITIVE INPUT CHANNEL.
    '*         TMR0 TIME BASE SETUP                                 *
    '*         ENABLE TMR0 TIMER INTERRUPTS                         *
    OPTION_REG = %11100011       'Bit 2-0, 011= prescaler rate 1:16 (TMRO INTERRUPTS EVERY 4.096 mSec)
    INTCON = %01100000	     'enable TMR0 interrupts. enables all unmasked peripheral interrupts
    T1CON = %11000101            'Timer1 initialization
    T1GCON = %11100001           'Timer1 gate init /Toggle Mode/TMR0 time base
    PIR1.7 = 0                   'Clear Gate Interrupt Flag. Timer1 gate is active (TMR1GIF BIT)
    PIE1.7 = 1                   'Disable the Timer1 Gate Acquisition complete interrupt (TMR1GIE BIT)
    TMR0 = 0	             'TMR0 overflows every (256-TMRO)*(Prescaler rate)(4*(1/4)uS)=4096uSec.
    ON INTERRUPT GOTO ISR
    INTCON = %10100000           'Enable Interrupts
    '<                       MAIN PROGRAM                           >
    START:
        '0= PROGRAM HASN'T STARTED YET. 1= PROGRAM STARTED ALREADY (TOUCH BUTTON DETECTED).
        START_PROGRAM = 0
        WHILE START_PROGRAM = 0
            PAUSE 1
        WEND
    MAIN:
        FOR I = 1 TO 200
            PAUSE 1
        NEXT I
    GOTO MAIN
    '<                   INTERRUPT ROUTINE ISR                      >
    DISABLE			        'Disable further interrupts
    ISR:
        T1CON.0 = 0                 'Stop/Clears Timer1 before reading TMR1
        IF BUTTON = 0 THEN RAW_0.BYTE0 = TMR1L : RAW_0.BYTE1 = TMR1H
        IF BUTTON = 1 THEN RAW_1.BYTE0 = TMR1L : RAW_1.BYTE1 = TMR1H
        IF STABILIZE_CSM <> 0 THEN
            STABILIZE_CSM = STABILIZE_CSM - 1           'RUN CSM 2 TIMES BEFORE TAKING A READING
            IF BUTTON = 0 THEN AVERAGE_0 = 0
            IF BUTTON = 1 THEN AVERAGE_1 = 0
        'STABILIZING AVERAGE IF RAW OVERSHOOTS DURING STARTUP.
        IF BUTTON = 0 THEN
            IF AVERAGE_0 > (RAW_0 + 600) THEN AVERAGE_0 = 0
        IF BUTTON = 1 THEN
            IF AVERAGE_1 > (RAW_1 + 600) THEN AVERAGE_1 = 0
        'SIMPLE DETECTION. IF RAW < AVERAGE*(1-2.0%)
        IF BUTTON = 0 THEN
            IF RAW_0 < (AVERAGE_0 - (AVERAGE_0/TRIP)) THEN
                LED_0 = 1
                PAUSE 500
                LED_0 = 0
                AVERAGE_0 = 0               'AVOIDS SECOND FALSE READINGS
                STABILIZE_CSM = 2           'HELPS STABILIZE CSM TO AVOID FALSE READINGS
                START_PROGRAM = 1              'ONLY USED AT START OF PROGRAM (=0 NO BUTTONS TOUCHED YET)
                BUTTON = 1                  'SWAP BUTTON BIT
                CPSCON1 = %00000100         'CHANGE BUTTON CAPACITIVE INPUT CHANNEL
                AVERAGE_0 = RAW_0
                CPSCON1 = %00000000
            IF RAW_1 < (AVERAGE_1 - (AVERAGE_1/TRIP)) THEN
                LED_1 = 1
                PAUSE 500
                LED_1 = 0
                AVERAGE_1 = 0               'AVOIDS SECOND FALSE READINGS
                BUTTON = 0                  'SWAP BUTTON BIT
                CPSCON1 = %00000000         'CHANGE BUTTON CAPACITIVE INPUT CHANNEL
                AVERAGE_1 = RAW_1
                CPSCON1 = %00000100
        TMR1L = 0               'Reset Timer1
        TMR1H = 0
        T1CON.0 = 1             'Restart/Enable Timer1 (TMR1ON BIT)
        TMR0 = 0                'RESET TMR0 TO 0
        INTCON.2 = 0		    'Re-enable TMR0 interrupts. Bit 2, 0= clears overflow, 1= overflow ocurred
        RESUME				    'Return to main program
        ENABLE				    'Enable interrupts
     END				        ' End of program
    One of the differences that I can see between my program and Byte_Butchers is OPTION_REG.5. I have it set to one and Byte_Butcher's have it cleared. OPTION_REG.5 set to one means that the TMR0 clock source is the CPSOSC signal and if cleared means the clock source is the internal instruction cycle clock. It works either way because I have tried it. However, AN1171 "CSM using PIC16F72x" and the datasheet suggests to clear this bit, so I guess that would be the right thing to do.
    Another difference between the two programs is CPSCON0.1. If set to 1 means the oscillator is sourcing current out of the pin and if cleared means the opposite. Again, It works either way but I don't know what would be the right way.
    By experimenting with the program and displaying the different variables in the PC monitor through a serial connection I could come up with the above detection algorithm, which I can say it's pretty accurate (so far).
    Finally, I want to say that testing this kind of CSM circuits on a breadboard (like I did) and using two adjacent pins on the MCU for CSM detection (like I also did) is not a very good idea. If you do that there will be some crosstalk interference between the two touch pads and touching one button will activate the other one. Apparently a breadboard is not good for this kind of circuits.
