Interruptus Frustratus
Results 1 to 17 of 17
    California, USA
    It protect what's in between DISABLE and ENABLE, so yes if your Gosub are in between them, they will be "protected" as well.
    Excellent. Thanks!
    Woohoo! Go TEAM Go!
    And just to add more info ...
    When a 16F PIC is servicing an interrupt, no other interrupts can occur until the current one is finished. The GIE bit is cleared automatically by hardware at the start of the interrupt. Global ints are then re-enabled when it executes a RETFIE (return from interrupt) at the end of the handler.
    So there's no need to try to keep a handler from being interrupted, because it can't.
    With ON INTERRUPT, the actual Hardware INTERRUPT was serviced long before it gets to the handler, so you need to disable/enable with those.
    California, USA
    Shucks, last week I cudnt even spel PIC, and now I are programin one!
    Data Sheets and Application Notes are wonderful things, but sometimes there's no substitute for a good teacher(s) to help explain things, fill in the details, or to just shove me over a hurdle that I can't find my way around...
    I really appreciate ALL the folks who've taken time to help... but especially Darrel for creating good things like DT_INTS and then having the patience to put up with all the silly questions we newbies will certainly have about it!
    THANKS!
    It's been a good day. I learned a lot.
    Miami, Florida USA
    Hi all,
    I've been working in a project similar to byte_butcher's but using PBP only (I don't know any MPASM). My touch buttons work nicely but when I try to use GOSUB inside the ISR routine somehow PBP doesn't like it. I have my sub-routines outside the Disable-Enable of the ISR routine but it doesn't work.
    Am I missing something here?? Darrel said it is posible to call sub-routines when the interrupts are disable.
    Thanks in advance for any help.
    ... My touch buttons work nicely but when I try to use GOSUB inside the ISR routine somehow PBP doesn't like it. I have my sub-routines outside the Disable-Enable of the ISR routine but it doesn't work.
    If you are putting DISABLE/ENABLE around your interrupt handler ...
    can I assume you are using ON INTERRUPT?
    With ON INTERRUPT, the handler and any subroutines called by the handler MUST be inside DISABLE/ENABLE directives.
    But if at all possible, GOSUB's should be avoided entirely in any interrupt handler.
    Miami, Florida USA
    Thank you Darrel. That solves part of my problems in this project I'm working on.
    Miami, Florida USA
    Attached is some of my code (without all the other stuff that nobody cares about) of the Capacitive Sensing Module (CSM) that I'm working on. My project is similar to Byte_Butcher's but I'm only using PBP. There is still some work to be done like having some arrays would be nice, but so far the touch pads work fine.
    '*         DEFINING VARIABLES AND SETTING INITIAL VALUES        *
    DEFINE OSC          4       	    'Define Oscillator to 4MHz
    I               VAR WORD
    TRIP            VAR BYTE
    STABILIZE_CSM   VAR BYTE            'VARIABLE USED TO LET MCU STABILIZE CSM
    BUTTON          VAR BIT
    START_PROGRAM   VAR BIT             'ONLY USED AT START OF PROGRAM (=0 NO BUTTONS TOUCHED YET)
    RAW_0           VAR WORD
    RAW_1           VAR WORD
    AVERAGE_0       VAR WORD
    AVERAGE_1       VAR WORD
    LED_0           VAR PORTB.6
    LED_1           VAR PORTB.7
    TEST_VAR        VAR BYTE
    STABILIZE_CSM = 2                   'LET CSM RUN 2 TIMES BEFORE TAKING READINGS
    TRIP = 50                           'TRIP USED AS (1/50)*(AVERAGE)
    LED_0 = 0                           'LEFT BUTTON LED
    LED_1 = 0                           'RIGHT BUTTON LED
    RAW_0 = 0
    RAW_1 = 0
    AVERAGE_0 = 0
    AVERAGE_1 = 0
    BUTTON = 0                          'START WITH BUTTON 0 (LEFT)
    TEST_VAR = 0
    '*         CAPACITIVE SENSING MODULE INITIALIZATION             *
    TRISA = %00000000           'Initialize ports as outputs
    ANSELA = %00000000          'Initialize as digital ports
    TRISB = %00010001           'Initialize PortB.0 and PortB.4 as inputs.
    ANSELB = %00010001          'Initialize CPS4 and CPS0 as analog inputs.
    TRISD = %00000000           'INITIALIZE ALL PORTS AS OUTPUTS
    ANSELD = %00000000          'INITIALIZE ALL PORTS AS DIGITAL PORTS
    TRISC = %10000000           'INITIALIZE RC7 AS INPUT (SERIAL RX)
    CPSCON0 = %10001111         'CAPACITIVE SENSING MODULE IS ON. OSCILLATOR IS IN HIGH RANGE.
    CPSCON1 = %00000000         'BITS 3-0, 0000= RB0/CPS0 IS THE CAPACITIVE INPUT CHANNEL.
    '*         TMR0 TIME BASE SETUP                                 *
    '*         ENABLE TMR0 TIMER INTERRUPTS                         *
    OPTION_REG = %11100011       'Bit 2-0, 011= prescaler rate 1:16 (TMRO INTERRUPTS EVERY 4.096 mSec)
    INTCON = %01100000	     'enable TMR0 interrupts. enables all unmasked peripheral interrupts
    T1CON = %11000101            'Timer1 initialization
    T1GCON = %11100001           'Timer1 gate init /Toggle Mode/TMR0 time base
    PIR1.7 = 0                   'Clear Gate Interrupt Flag. Timer1 gate is active (TMR1GIF BIT)
    PIE1.7 = 1                   'Disable the Timer1 Gate Acquisition complete interrupt (TMR1GIE BIT)
    TMR0 = 0	             'TMR0 overflows every (256-TMRO)*(Prescaler rate)(4*(1/4)uS)=4096uSec.
    ON INTERRUPT GOTO ISR
    INTCON = %10100000           'Enable Interrupts
    '<                       MAIN PROGRAM                           >
    START:
        '0= PROGRAM HASN'T STARTED YET. 1= PROGRAM STARTED ALREADY (TOUCH BUTTON DETECTED).
        START_PROGRAM = 0
        WHILE START_PROGRAM = 0
            PAUSE 1
        WEND
    MAIN:
        FOR I = 1 TO 200
            PAUSE 1
        NEXT I
    GOTO MAIN
    '<                   INTERRUPT ROUTINE ISR                      >
    DISABLE			        'Disable further interrupts
    ISR:
        T1CON.0 = 0                 'Stop/Clears Timer1 before reading TMR1
        IF BUTTON = 0 THEN RAW_0.BYTE0 = TMR1L : RAW_0.BYTE1 = TMR1H
        IF BUTTON = 1 THEN RAW_1.BYTE0 = TMR1L : RAW_1.BYTE1 = TMR1H
        IF STABILIZE_CSM <> 0 THEN
            STABILIZE_CSM = STABILIZE_CSM - 1           'RUN CSM 2 TIMES BEFORE TAKING A READING
            IF BUTTON = 0 THEN AVERAGE_0 = 0
            IF BUTTON = 1 THEN AVERAGE_1 = 0
        'STABILIZING AVERAGE IF RAW OVERSHOOTS DURING STARTUP.
        IF BUTTON = 0 THEN
            IF AVERAGE_0 > (RAW_0 + 600) THEN AVERAGE_0 = 0
        IF BUTTON = 1 THEN
            IF AVERAGE_1 > (RAW_1 + 600) THEN AVERAGE_1 = 0
        'SIMPLE DETECTION. IF RAW < AVERAGE*(1-2.0%)
        IF BUTTON = 0 THEN
            IF RAW_0 < (AVERAGE_0 - (AVERAGE_0/TRIP)) THEN
                LED_0 = 1
                PAUSE 500
                LED_0 = 0
                AVERAGE_0 = 0               'AVOIDS SECOND FALSE READINGS
                STABILIZE_CSM = 2           'HELPS STABILIZE CSM TO AVOID FALSE READINGS
                START_PROGRAM = 1              'ONLY USED AT START OF PROGRAM (=0 NO BUTTONS TOUCHED YET)
                BUTTON = 1                  'SWAP BUTTON BIT
                CPSCON1 = %00000100         'CHANGE BUTTON CAPACITIVE INPUT CHANNEL
                AVERAGE_0 = RAW_0
                CPSCON1 = %00000000
            IF RAW_1 < (AVERAGE_1 - (AVERAGE_1/TRIP)) THEN
                LED_1 = 1
                PAUSE 500
                LED_1 = 0
                AVERAGE_1 = 0               'AVOIDS SECOND FALSE READINGS
                BUTTON = 0                  'SWAP BUTTON BIT
                CPSCON1 = %00000000         'CHANGE BUTTON CAPACITIVE INPUT CHANNEL
                AVERAGE_1 = RAW_1
                CPSCON1 = %00000100
        TMR1L = 0               'Reset Timer1
        TMR1H = 0
        T1CON.0 = 1             'Restart/Enable Timer1 (TMR1ON BIT)
        TMR0 = 0                'RESET TMR0 TO 0
        INTCON.2 = 0		    'Re-enable TMR0 interrupts. Bit 2, 0= clears overflow, 1= overflow ocurred
        RESUME				    'Return to main program
        ENABLE				    'Enable interrupts
     END				        ' End of program
    One of the differences that I can see between my program and Byte_Butchers is OPTION_REG.5. I have it set to one and Byte_Butcher's have it cleared. OPTION_REG.5 set to one means that the TMR0 clock source is the CPSOSC signal and if cleared means the clock source is the internal instruction cycle clock. It works either way because I have tried it. However, AN1171 "CSM using PIC16F72x" and the datasheet suggests to clear this bit, so I guess that would be the right thing to do.
    Another difference between the two programs is CPSCON0.1. If set to 1 means the oscillator is sourcing current out of the pin and if cleared means the opposite. Again, It works either way but I don't know what would be the right way.
    By experimenting with the program and displaying the different variables in the PC monitor through a serial connection I could come up with the above detection algorithm, which I can say it's pretty accurate (so far).
    Finally, I want to say that testing this kind of CSM circuits on a breadboard (like I did) and using two adjacent pins on the MCU for CSM detection (like I also did) is not a very good idea. If you do that there will be some crosstalk interference between the two touch pads and touching one button will activate the other one. Apparently a breadboard is not good for this kind of circuits.
