ADC Problem with PIC16F88 Configuration
Results 1 to 5 of 5
    Dec 2008
    Unhappy ADC Problem with PIC16F88 Configuration
    I am using PortA.0, PortA.1 and PortA.2 to read the individual values for my line following sensor. The sensor is a TCRT5000 device x 3.
    Here is my code, any ideas please ?
    @ DEVICE XT_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    DEFINE LOADER_USED 1
    Include "Modedefs.Bas"
    Define OSC 4 ' We're using a 4MHz Resonator
    define DEBUG_REG PORTB ' DEBUG PORT
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_PACING 500
    CLR CON 1 ' CLR LCD command
    LINE1 CON 128 ' LCD line #1
    LINE2 CON 192 ' LCD line #2
    LINE3 CON 148 ' LCD line #3
    LINE4 CON 212 ' LCD line #4
    INS CON 254 ' LCD command mode parameter
    DEFINE ADC_BITS 8 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    TRISA = %11111111 'RA.0:3 Input
    TRISB = %00000000 'all PORTB output
    'ANSEL = %00000001 'only porta.0 is analogue
    ADCON1 = %00000010 'right justify the result(top bits are read as zero)
    CMCON = 7 'Turn off comparators
    piezo var portb.7
    LOW PIEZO
    msensor var word
    lsensor var word
    rsensor var word
    ' motor driver logic to 0 - low all port pins
    low portb.0
    low portb.1
    low portb.3
    low portb.4
    init:
    DEBUG INS,CLR
    pause 30
    DEBUG INS,LINE1,"L= R= " : PAUSE 30
    DEBUG INS,LINE2,"M= " : pause 30
    checkit:
    ANSEL = %00000001 ' Only porta.0 is analogue
    ADCON0 = %01000101 ' Control register 000 RA0/AN0
    adcin porta.0,lsensor
    DEBUG INS,LINE1+3, dec lsensor," " : pause 30
    ANSEL = %00000010 'only porta.1 is analogue
    ADCON0 = %01001101 ' Control register 000 RA1/AN1
    adcin porta.1,msensor
    DEBUG INS,LINE2+3, dec msensor," " : PAUSE 30
    ANSEL = %00000100 'only porta.2 is analogue
    ADCON0 = %01010101 ' Control register 000 RA1/AN1
    adcin porta.2,rsensor
    DEBUG INS,LINE1+11, dec rsensor," " : pause 30
    goto checkit
    ADCIN must use the channel number, not the PIN name.
    ADCIN 0, YourVar ---> read PORTA.0, AN0
    ADCIN 2, YourVar ---> read PORTA.2, AN2
    ADCIN 6, YourVar ---> read PORTB.7, AN6
    HTH
    You don't need to redefine ADCON0 and ANSEL all the time, only once at the top, and ADCIN should handle everything for you.
    Dec 2008
    Wink Pic16f88 a/d
    OK, I got it....
    I ended up doing like this in the end :
    DEFINE DEBUG_BIT 6 ' *** Debug pin Bit ***
    DEFINE DEBUG_BAUD 2400 ' *** Debug Baud Rate ***
    Define DEBUG_MODE 1 ' Set Serial Mode 0=True, 1=Inverted
    Define DEBUG_PACING 500 ' Delay 'in Us' between characters sent
    ' ** Port configurations **
    TX VAR PORTB.5 ' Bootloader connection for TX
    RX VAR PORTB.2 ' Bootloader connection for RX
    PIEZO var PORTB.7 ' On board Piezo
    IR_REC VAR PORTA.3 ' On board Infrared Receiver
    LOW PIEZO
    low portb.0
    low portb.1
    low portb.3
    low portb.4
    ' *** Clear Serial LCD ***
    DEBUG Ins,clr : PAUSE 30
    ' *** Setup Line 1 and Line 2 ***
    DEBUG Ins,LINE1,"Left Mid Right" : PAUSE 30
    DEBUG ins,LINE2," " : PAUSE 30
    TRISA = %11111111 ' All PORTA Inputs
    TRISB = %00000000 ' All PORTB output
    ANSEL = %00000111 ' Set 0,1,2 to A/D, A/D clock = Frc
    RESULT VAR BYTE[3] ' 3-BYTE ARRAY STORAGE FOR 3 A/D CONVERSIONS
    C VAR BYTE ' ADC CHANNEL NUMBER BYTE VARIABLE
    MAIN:
    FOR C = 0 TO 2 ' 3-CHANNEL COUNTER LOOP
    ADCIN C, RESULT[C] ' Read all 3 channels
    PAUSE 10 ' Pause 10mS
    NEXT C
    PAUSE 250 ' PAUSE 250mS
    DEBUG ins,LINE2,dec RESULT[0]," "
    debug ins,line2+6,dec RESULT[1]," "
    debug ins,line2+11,dec result[2]," "
    GOTO MAIN ' DO IT AGAIN
    END ' END PROGRAM
    Dec 2008
    Default Pic16f88 a/d
    Thank you for your help MR. E
  1. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  2. 16F88 ADC problem
    By greensasquatch in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 17:16
  3. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 18:47
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  5. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 18th September 2006, 00:31
