Low key count membrane keypads
Results 1 to 7 of 7
    Brussels, Belgium
    Default Low key count membrane keypads
    Anyone know of a cheap source for 3 or 4 key membrane keypads ? It is easy enough to find expensive ones from parts suppliers but I can't find anything on eBay. Or to look it it another way, if you had a project that only needed 4 keys for data entry, is there a more elegant way than 4 push button momentary switches drilled through the front panel ? The most elegant is undoubtedly a touch screen GDU but I'm not going that way - yet !
    Andrew
    May 2008
    Italy
    Andrew, you can disassemble a piezo buzzer and use the internal as a pushbutton. Just connect the two wires one to ground and one to the input (better if you protect the input with a zener) use the DT interrupt routine and you will see the piezo element switching your interrupt all the time you press it.
    Mind the polarity.
    Al.
    Tact switches mounted on a pcb, some hole on the front plate, and a home made (or any other much fancy place) membrane to stick over the whole thing (front-plate). Neat enough, cheap enough, easy to repair/modify too.
    Brussels, Belgium
    Scary parallel processing - I've got a piece of scrap PCB at home with a tact switch covered with some clear silicone which is drying. I'm hoping the silicone will have not penetrated the switch but will provide a flexible enough seal over it.
    Andrew
    Check out this keypad at Sparkfun. It is a silicon 2x2 with LED backlight. Kinda neat and you can build up other key matrixes using the parts. They also have 4x4, a 3 button gamepad like, and a 12 key membrane. The 4x4 can be cut in half to make 2 2x4 pads.
    Tim Barr
    Brussels, Belgium
    Quote Originally Posted by falingtrea View Post
    they've got some nice keypads there - thanks
    Brussels, Belgium
    Quote Originally Posted by aratti View Post
    Mind the polarity.
    Al.
    Now that sounds interesting.
  1. 8x8 keypad matrix...
    By mbox in forum General
    Last Post: - 9th October 2014, 18:43
  2. Complete Keypad Example
    Last Post: - 27th July 2011, 19:09
  3. PIC - PIC Comm
    By dgcarter in forum mel PIC BASIC Pro
    Last Post: - 1st February 2009, 22:19
  4. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 03:14
