Morse code reader compiles but won't run
Results 1 to 4 of 4
    Apr 2009
    Default Morse code reader compiles but won't run
    We have a club project to read morse code from a speaker and display it on an LCD . The code compiles without error but won't run. I have used MPLBAsim but can't get it to work. It is coded for an 16F84 at 4 MHZ and a Hitachi LCD. Need some help. I have attached the code as text Morse2.txt
    timmers's Avatar
    timmers Guest
    Wink
    __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC
    ; timing based on 1.12MHz RC oscillator configuration using 5.1Kohm + 100pf
    Hi there,
    Your first problem is you've defined a high speed oscillator but have an RC circuit connected instead.
    Change your config line to
    __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _RC_OSC
    For time critical applications a ceramic resonator or crystal is much more reliable. Dont forget the load capacitors for the crystal!
    Tim.
    Apr 2009
    Default reply
    I figured that I should get something out of the chip even with a 4MHZ xtal. But I guess it throws all the timing off, even for the LCD. I will make the appropriate changes and get back. I was suprised I couln't get it to run on MPLabSim. It wouldn't even click over 1 cycle. I am a newbie at MPLabSim so I may not have had it set up right. I get an error:
    CORE-W0014: Halted due to PC incrementing over the Maximum PC address and wrapping back to Zero
    timmers's Avatar
    timmers Guest
    Hmmm... gave up with Microchip machine code severeal years ago, -not easy to work with.
    Its allways worth adding an LED to a spare pin, just to give a heartbeat confidence flash, to indicate its doing something.
    Tim.
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Making Program Code Space your playground...
  3. Timer PIC16F57
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 09:14
  4. Writing code for battery operated projects
    Last Post: - 16th June 2005, 04:39
  5. Line following robot... problems with some code
    By nepstar in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 02:10
