Define osccal_1k 1
Results 1 to 4 of 4
    Aug 2005
    down south
    Default Define osccal_1k 1
    most of my programming is done with 12f629/75 , and 16f630/76
    I have read that it is a good practices to added this define when using OSC
    DEFINE OSCCAL_1K 1
    my ? is do I still need to add
      pic12F629
     @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
     Define OSCCAL_1K 1
     DEFINE OSC 4    'INTERNAL CLOCK SPEED 4MH.
    thanks grounded
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    DEFINE OSC and OSCCAL_1K are two different animal.
    DEFINE OSC just define the OSC speed, while OSCCAL call the factory internal oscillator calibration to tweak the accuracy as much as possible.
    Better explanation, and in real English
    http://www.rentron.com/PIC12C67X.htm
    If you don't use DEFINE OSC 4, the compiler will include it for you in background.
    Aug 2005
    down south
    thanks for the link
    you second post answered my ?
    I had seen code that had it and some that did not and now I know you just don't have to.
    thanks
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
