Data transmition using lasers?
Results 1 to 15 of 15
    I would think the target would need "painted" for a certain amount of time to count? Then you want to identify who hit it?
    Have each laser pulse at a different rate. 75hz, 100hz 125hz... Doable with cheap lasers.
    Then have the target PIC COUNT the incoming pulses for a second. If the COUNT variable = 100 then whatever.
    I use a similar method for a "laser fence". If the target does not see Xhz then the alarms sound. A photo-transistor sits in the bottom of a reflective funnel about 2 inches in diameter at the opening for the target.
    Oct 2008
    ok that sounds like a pritty good idea and somthing i hadnt even considered!
    So just a simple 555 timer switching a transistor to the laser with the pic at the reciever with a rang of if signal is 190-210 then target is hit by laser 01 etc?
    any chance of seeing a rough circuit diagram of the way that you did it?
    cheers! chris
    I am using a PIC running at 3 volts and a logic level Mosfet (NPN) to the laser. A 555 would also work but for me it is easier to program the pulse I want. Sorry, I can not find a drawing.
    This thead has the drawing for the target.
    http://www.picbasic.co.uk/forum/showthread.php?t=6826
    Oct 2008
    Thanks again!
    I shall try my best to have a play with this over the next few weeks.... Ive got my college project to work on first though!
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
