Mack,
Thank you for your help today. I can't believe I had so much trouble with that. I wrote a program in mumps a few years ago that converted a number to base 36 for this wacky interface checksum I had to write and I don't think I struggled that hard.
I was able to use my knew found logic and incoporate that same philosphy into my 10 bit program I originally started to work on but stepped back from to get the 8bit to work and understand this a little better. I know you pointed out a couple things about the high and low bits. I won't try to kid you I am not sure what you were trying to tell me there. I put this program together from bits and pieces by looking at others and their examples.
I can run this side by side with the 8 bit program and I get the same results. Is there any advatage of reading the analog value using ADCIN vs. Bruces example? Any disadvatages?
Thanks again today.
David
INCLUDE "modedefs.bas"
' Hardware specific settings
@ DEVICE pic16F877, XT_OSC ' System Clock Options
@ DEVICE pic16F877, WDT_ON ' Watchdog Timer
@ DEVICE pic16F877, PWRT_ON ' Power-On Timer
@ DEVICE pic16F877, BOD_ON ' Brown-Out Detect
@ DEVICE pic16F877, LVP_ON ' Low-Voltage Programming
@ DEVICE pic16F877, CPD_OFF ' Data Memory Code Protect
@ DEVICE pic16F877, WRT_ON ' Flash Memory Word Enable
' ADC definitions 16F877 - (8) 10bit channels
DEFINE ADC_BITS 10 ' (8) 10 Bit channels
DEFINE ADC_CLOCK 3 ' tell the us per osc clock tick?
DEFINE ADC_SAMPLEUS 50 ' how long to sample the pin
DEFINE OSC 10
DEFINE LOADER_USED 1
'INIT ADC
ADCON1 = %10001110 ' Just one analog input needed see page 112 of 16f877 spec
ADCON0 = %11000001 ' Analog converter Fosc/32, ADC module is ON
ADCON0.7 = 1 'I DID THAT ABOVE RIGHT DO I NEED TO RESET THIS OR
'DID MISS SOMETHING ABOUT SETTING VALUES THIS WAY?
'Varibles
SO VAR PORTC.6
ADval VAR word ' Storage for A/D result
PRESSURE VAR word
PRESS VAR word
ADavg VAR WORD[2]
READING var byte
Value VAR WORD
RES var word
'CONSTANTS
AvgCount CON 64 ' = Number of samples to average
FAspread CON 25 ' = Fast Average threshold +/-
BAUD CON 32
'****START OF PROGRAM*****
BEGIN:
SerOut2 SO,baud,[12,"Hello World 10 bit AD Test",10,13]
pause 2000
Serout2 so,baud,[27,"[2;1H","Pressure: "]
MAINLOOP:
ADCIN 0,adval ' Read A/D channel 0 to adval variable
adval = adval - 96
res = adval * 1953
adval = div32 1000
'average out press first before calcuating true pressure
READING = 1
value = adval
gosub average
press = value
Serout2 so,baud,[27,"[2;11H",DEC5 PRESS]
'PRESSURE = ( 58 * PRESS - 58 ) / 100
'pressure = ( 1464 * press - 1464 ) / 10
'value = pressure
'READING = 2
'GOSUB AVERAGE
'PRESSURE = VALUE
'Serout2 so,baud,[27,"[1;11H",DEC5 PRESSURE]
Pause 200 ' Wait period between updates
GOTO MAINLOOP
' -=-=-=-=-=-= Average Analog values -=-=-=-=-=-=-=-=-=-=
' compliments of Darryl Taylor
AVERAGE:
IF Value = ADavg[READING] Then NoChange
IF ABS (Value - ADavg[reading]) > FAspread OR Value < AvgCount Then FastAvg
IF ABS (Value - ADavg[reading]) < AvgCount Then RealClose
ADavg[reading] = ADavg[reading] - (ADavg[reading]/AvgCount)
ADavg[reading] = ADavg[reading] + (Value/AvgCount)
GoTo AVGok
FastAvg:
ADavg[reading] = Value
GoTo AVGok
RealClose:
ADavg[reading] = ADavg[reading] - (ADavg[reading]/(AvgCount/4))
ADavg[reading] = ADavg[reading] + (Value/(AvgCount/4))
AVGok:
Value = ADavg[reading] ' Put Average back into Value
NoChange:
Sometimes a capacitor from the ADC pin to zero will help smooth thing out, This may even be needed with some 8 bit applications.
