Help with pressure sensor.
Results 1 to 27 of 27
    Jan 2008
    Pennsylvania
    Your reading is 24 or 25...
    Try calculating 24/255*5v = 0.470v...
    Close enough for you?
    BTW... you can't use the above math in PBP as you have to scale it up a little to maintain INTEGER integrity, but I'm sure you can figure how to do that.
    Yes, Not sure why I am getting this math all assbackwards. I think I've spent to many years as a mumps programmer. I think I get this part so far. My range of .5 to 4.5 isn't relivant... yet. the 24/25 reading is going off a REF of 5v which as you pointed out makes complete sense to me. I keep frogetting to take that into account but I am learining and willing to learn. I jsut can't seem to get past that part I think I need to programatically figure out how to factor in my range is only going to be .5 to 4.5 or 0 to 4 or I must have to give the pic a VREF. If you can point me in the right direction I would appreciate it.
    With in mind and I believe I get it so far I will post the program that I have been working on with some success. I think I am close.
    Here is my program and my logic/math
    So if my scale is 0-1024 with an internal ref of 5v and using an earlier example form Mack I would conclude give my sensor range of 0-150psi with an proportinate output voltage of .5 to 4.5v then...
    (150-0) / (4.5-.5) = 37.5 psi per volt
    150/1024 at a 5v ref range is .1464 psi per reading
    That part I understand completely. The next part is were I am lost.
    Converting the .5 -> 4.5v with an offset somehow so that works out to
    0 -> 4 then calculating out that voltage to PSI which would be easy would it not be my vdc * 37.5?
    0-1024 with a 5v ref gives me .0048 volts per incrment or 204.8 increments per volt. If I leave the 5v ref as it is then I think my offset would be -102.4 so to get the PSI reading I would take:
    Given ADVal = reading from the ad result
    ( ADVal - 102.4 ) * .1464
    Let's say I know the PSI is 75 then the calc should work... Half of 1024 would be 512 so ( 512 - 102.4 ) * .1464 = 59.96
    but... my reading would not be 512 for 75 psi it would be 512+102.4 right? arghhhhhhhh I'l be back I have to sweep up the last of my hair!
    Thanks for your help. I am trying.
    P.S. It's a beautiful day here in Pennsylvania
    David
    INCLUDE "modedefs.bas"
    ' Hardware specific settings
    @ DEVICE pic16F877, XT_OSC ' System Clock Options
    @ DEVICE pic16F877, WDT_ON ' Watchdog Timer
    @ DEVICE pic16F877, PWRT_ON ' Power-On Timer
    @ DEVICE pic16F877, BOD_ON ' Brown-Out Detect
    @ DEVICE pic16F877, LVP_ON ' Low-Voltage Programming
    @ DEVICE pic16F877, CPD_OFF ' Data Memory Code Protect
    @ DEVICE pic16F877, WRT_ON ' Flash Memory Word Enable
    ' ADC definitions 16F877 - (8) 10bit channels
    DEFINE ADC_BITS 10 ' (8) 10 Bit channels
    DEFINE ADC_CLOCK 3 ' tell the us per osc clock tick?
    DEFINE ADC_SAMPLEUS 50 ' how long to sample the pin
    DEFINE OSC 10
    DEFINE LOADER_USED 1
    'INIT ADC
    ADCON1 = %10001110 ' Just one analog input needed see page 112 of 16f877 spec
    ADCON0 = %11000001 ' Analog converter Fosc/32, ADC module is ON
    'ADCON0.7 = 1 I DID THAT ABOVE RIGHT?
    'Varibles
    SO VAR PORTC.6
    ADval VAR word ' Storage for A/D result
    PRESSURE VAR word
    PRESS VAR word
    ADavg VAR WORD[2]
    READING var byte
    Value VAR WORD
    'CONSTANTS
    AvgCount CON 64 ' = Number of samples to average
    FAspread CON 25 ' = Fast Average threshold +/-
    BAUD CON 32
    '****START OF PROGRAM*****
    BEGIN:
    SerOut2 SO,baud,[12,"Hello World AD Test",10,13]
    pause 2000
    Serout2 so,baud,[12,27,"[1;1H","Pressure: "]
    MAINLOOP:
    ADCIN 0,adval ' Read A/D channel 0 to adval variable
    Serout2 so,baud,[27,"[3;11H",DEC5 adval]
    'average out press first before calcuating true pressure
    READING = 1
    value = adval
    gosub average
    press = value
    Serout2 so,baud,[27,"[2;11H",DEC5 PRESS]
    'PRESSURE = ( 58 * PRESS - 58 ) / 100
    pressure = ( 1464 * press - 1464 ) / 10
    value = pressure
    READING = 2
    GOSUB AVERAGE
    PRESSURE = VALUE
    Serout2 so,baud,[27,"[1;11H",DEC5 PRESSURE]
    Pause 200 ' Wait period between updates
    GOTO MAINLOOP
    ' -=-=-=-=-=-= Average Analog values -=-=-=-=-=-=-=-=-=-=
    ' compliments of Darryl Taylor
    AVERAGE:
    IF Value = ADavg[READING] Then NoChange
    IF ABS (Value - ADavg[reading]) > FAspread OR Value < AvgCount Then FastAvg
    IF ABS (Value - ADavg[reading]) < AvgCount Then RealClose
    ADavg[reading] = ADavg[reading] - (ADavg[reading]/AvgCount)
    ADavg[reading] = ADavg[reading] + (Value/AvgCount)
    GoTo AVGok
    FastAvg:
    ADavg[reading] = Value
    GoTo AVGok
    RealClose:
    ADavg[reading] = ADavg[reading] - (ADavg[reading]/(AvgCount/4))
    ADavg[reading] = ADavg[reading] + (Value/(AvgCount/4))
    AVGok:
    Value = ADavg[reading] ' Put Average back into Value
    NoChange:
    Do not mix up the ADCIN defines and the bit banging from Bruce's example.
    Some more reading..
    http://www.picbasic.co.uk/forum/showthread.php?t=2188
    And a snippet for 10 bit banging..
    ADCON1.7 = 1
    	gosub getAD
    	press.highbyte = ADRESH
    	press.lowbyte = ADRESL
    Do a search for 10 bit ADC also..
    http://www.picbasic.co.uk/forum/showthread.php?t=4751
    Jan 2008
    Pennsylvania
    Some more reading..
    ADCON1.7 = 1
    	gosub getAD
    Mack, Malanie Ok so let me step backwards and make this simple. Let's go back to Bruce's example first and get that working first as you suggested I got ahead of myself.
    Per Melanie and Bruce's example the pic is right on. My reading of 24
    24/255*5v = 0.470v
    So let me work on that. That would mean that for every bascially .5 volt I would see my count add 24 (I realize it's .47 but for the sake of argument we'll say .5) So for 1 volt it would be 48 then 1.5 volt 72 etc to 4.5 volt top out on my sensor at 216 reading.
    If I got from 24 = 0 PSI to 216 = 150 PSI that would be 216-24 for 192 increments at a max of 150psi = .78125 PSI per incrment. So the calculation would be
    ( adval - 24 ) * .78125
    ( 24 - 24 ) * .78125 = 0
    (120 - 24 ) * .78125 = 75
    ( 216 - 24 ) * .78125 = 150
    Right half way between 216 and 24 would be 96 + the offset of 24 I would get a reading of 120 so 120 - 24 = 96 * .78125 = 75
    I think I got this so far.
    I don't know why I am struggling with this so much but I think this is right so far. This looks correct to me so far let me hook this up to my compressor and take a look
    David
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Replies: 6
    Last Post: - 18th January 2008, 09:17
  5. 1-Wire Pressure Sensor
    By Mith in forum mel PIC BASIC Pro
    Last Post: - 13th August 2005, 01:32
