lcd menu problems
Results 1 to 5 of 5
    Mar 2009
    posttemp sure looks like a word to me. Try changing it to a word variable.
    and its working just fine
    THX a lot
    www.mtskola.com
    Mar 2009
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 24/02/2009                                        *
    'pic defines
    	@ DEVICE pic16F887, WDT_OFF        ' Watchdog Timer
    	@ DEVICE pic16F887, PWRT_ON        ' Power-On Timer
    	@ DEVICE pic16F887, MCLR_ON        ' Master Clear Options (Internal)
    	@ DEVICE pic16F887, BOD_ON         ' Brown-Out Detect
    	@ DEVICE pic16F887, LVP_OFF        ' Low-Voltage Programming
    	@ DEVICE pic16F887, CPD_OFF        ' Data Memory Code Protect
    	@ DEVICE pic16F887, PROTECT_OFF    ' Program Code Protection
    'konfigurisi AN pinove kao digital I/O, portd kao I
    ansel=$00
    anselh=$00
    TRISD=$00
    portd=$00
    ' Definisanje hser-a (transmit-recive) i lcd-a u 4 bitnom modu
    define OSC 4
    DEFINE HSER_SPBRG 25
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE LCD_BITS 4
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_LINES 2
    'definisanje varijabli
    SYMBOL sel = PORTA.0 ' Sw 1 "select"
    SYMBOL enter = PORTA.2 ' Sw 3 "ENTER"
    T1 VAR BYTE
    T1=20
    ' promjenjive
    MENU VAR BYTE ' zeljeni MENU
    POSI VAR BYTE ' Pozicija na LCD
    temp Var Word			' temperatura kao word
    cr Var Byte			    ' ostatak
    cpc Var	Byte			' broji po stepenu C
    ow	Var	PORTE.2			' One-wire data pin
    i var byte              ' brojac
    posttemp var word
    ' incijalizacija
    low portc.6
    low porte.2
    PAUSE 300       ' LCD inicijalizacija
    LCDOUT $FE,1    ' ocisti LCD
    MENU = 1        ' Inicijalizacija variablli
    LCDOUT $FE,130," DOBRO DOSLI"
    lcdout $FE,$c0,128, "izaberite temp "
    ' meni switc select temp
    izbor:
    PAUSE T1
    IF sel = 1 THEN
     LCDOUT $FE,1'ocisti lcd
        MENU = MENU + 1
        gosub amenu
        pause 200
        IF MENU = 5 THEN MENU = 1
       ' for i = 1 to 4
        if menu = 1 and enter=1 then gosub sc
        if menu = 2 and enter=1 then gosub sc
        if menu = 3 and enter=1 then gosub sc
        if menu = 4 and enter=1 then gosub sc
       ' next i
    GOTO izbor
    'odabir za prikaz na displeju
    AMENU:
    SELECT CASE MENU
    CASE 2
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"1."," 28.00" , " C"
    POSI = 193 : LCDOUT $FE,POSI,"2."," 30.00" , " C"
    CASE 3
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"2."," 30.00" , " C"
    POSI = 193 : LCDOUT $FE,POSI,"3."," 32.00" , " C"
    CASE 4
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"3."," 32.00", " C"
    POSI = 193 : LCDOUT $FE,POSI,"4."," 34.00" , " C"
    CASE 5
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"4."," 34.00", " C"
    POSI = 193 : LCDOUT $FE,POSI,"1."," 28.00", " C"
    END SELECT
    'provjera temperature
    sc:
    'ovdje probati napraviti select case
    if menu = 2 then
    posttemp=$0AF0' postemp = 2800
        LCDOUT $FE,1, "Max temperatura:"
        lcdout $FE,$c0,128, "28.00 C"
        pause 2000
    if menu = 3 then
    posttemp=$0BB8
        lcdout $FE,$c0,128, "30.00 C"
        pause 2000
    if menu = 4 then
    posttemp=$0C80
        lcdout $FE,$c0,128, "32.00 C"
        pause 2000
    if menu = 1 then
    posttemp=$0D48
        lcdout $FE,$c0,128, "34.00 C"
        pause 2000
    goto sc1
    sc1:
       OWOut ow, 1, [$CC, $44]       ' pocni temp konverziju
    wc:
       OWIn ow, 4, [cr]	' provjeri da'l se jos konvertuje
       If cr = 0 Then wc
       OWOut ow, 1, [$CC, $BE]		' ocitaj temp
       OWIn ow, 0, [temp.LOWBYTE, temp.HIGHBYTE, Skip 4, cr, cpc]
       ' izracunaj temp u C na 2 decimale
      temp = (((temp >> 1) * 100) - 25) + (((cpc - cr) * 100) / cpc)
       Lcdout $fe, 1," temp:",DEC (temp / 100), ".", DEC2 temp, " C"' prikazi temp
                if temp >= posttemp then gosub s3    ' ako je veca od izabrane salji poruku!
       pause 2000
      goto sc1
    s3:
    high portb.6
    pause 2000
    low portb.6
    so u have a simple lcd menu and two switch, porta.0 seleect switch and porta.2 enter switch, if temp(from ds18B20) >= posttem (selected temperature form lcd menu) take action gosub s3
    www.mtskola.com
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 07:03
  5. LCD will not start
