Can someone please give me a indication what i am do-ing wrong i am trying to get serial coms running on a PIC12 but keeps on getting garbage the idea is to build a small data logger one input, rs232 coms and a spi ram chip
Code:DEFINE OSC 4 DEFINE ADC_BITS 10 '10 BIT A/D CONVERSION RESULT DEFINE ADC_CLOCK 3 'INTERNAL A/D RC CLOCK DEFINE ADC_SAMPLEUS 50 'SET SAMPLE TIME IN MICROSECONDS adval0 VAR WORD 'Create adval0 to store result DATAH VAR BYTE DATAL VAR BYTE CMCON = 7 'TURN COMPARITORS OFF TRISIO = %000001 'Set GSIO 0 INPUTS, others to OUTPUT ANSEL = %00110001 'Set GSIO 0 TO ANALOG A/D IN W/Frc ADCON0.7 = 1 'Right Justify for 10-bit DEFINE DEBUG_REG GPIO 'Set Debug pin port DEFINE DEBUG_BIT 2 'Set Debug pin bit DEFINE DEBUG_BAUD 4800 'Set Debug baud rate DEFINE DEBUG_MODE 1 'Set Debug mode: 0=true,1=inverted DEFINE DEBUGIN_REG GPIO 'Set Debugin pin por DEFINE DEBUGIN_BIT 1 'Set Debugin pin bit DEFINE DEBUGIN_BAUD 4800 'Set Debugin baud rate DEFINE DEBUGIN_MODE 1 'Set Debugin mode: 0=true,1=inverted START: TOGGLE GPIO.4 PAUSE 1000 DEBUG "D" GoTo START End
