wait for a string
Results 1 to 12 of 12
    May 2008
    Italy
    This snippet should solve your problem.
    EEprom 0,[49,55,49,55,49,48,57,53,57]  '  your number without the area code 1717101959
    InBox    var Byte  [8] ' make your array larger so you can use a byte as command
    Num0    var Byte  [9]
    Num1    var Byte  [9]
    Flag      var byte
    Try        var Byte
    A0        var Byte
    For A0=0 to 9
    Read A0,Num0[A0] ' here you load you number in array Num0
    Next A0
    IniCall:
    Try=Try+1
    If Try>5 then delet_sms ' if counter >5 then abort ( if 5 cycles are too many reduce them to an acceptable number)
    SerOut2 txd,Baud,["at+cmgr=5",13]
    SerIn2 rxd,Baud,1000,IniCall,[wait ("+880"),Str Num1\9,skip 32,str inbox\8] ' here you load the incoming number into array Num1
    Try=0
    Flag=1
    For A0=0 to 9
    If Num0[A0]<>Num1[A0] then Flag=0 ' here you compare the two array if not all digits agree then Flag is set to zero
    next A0
    If flag=0 then delet_sms ' flag reports "not corrected number" so delete sms
    'your code here to work with the array  inbox
    goto mainLoop ' your code mainLoop
    delet_sms:
    Try=0
    ' your code for deleting sms
    'If you make an  inbox array equal to 11 elements then you can use it to change the number when needed
    For instance if inbox[10]= 100 then gosub Change
    Change:
    For A0 =0 to 9
    Write A0, inbox[A0]
    Num0[A0]=inbox[A0]
    Next A0
    Your number is stored into the eeprom and is loaded in the array Num0 at runtime. I am not sure if "880" is the area code.
    If Try>5 then there is not sms, so you don't need to delete it. Trying to delete is dangerous because you could delete an incoming sms.
    Al.
    My question still is what if you have deleted all SMS and the new valid arrives at location 1?
    Mar 2009
    Wink
    sms index 1,2,3,4 are used to store the emergency sms. These sms are used to notify the user .
    Mar 2009
    Thumbs up thanks aratti
    Hi aratti . Thanks for your help. I have solved it.
    Can you please inform me one more thing, When any new sms arrived, the GSM modem send a notification " +CMTI: "SM",5 " .
    How i can use this notification to interrupt in my program.
    Your program might be interrupted only by an Hardware Interrupt, say from the USART module.
    So, if you want a fast interrupt system, have a look at Darrels Instant Interrupt.
    Then every time you have an RS-232 activity, the ISR will take care of the event. Store the incoming data in an array and do a compare byte-to-byte with a stored reference array, say in the EEPROM.
    I am working on a similar project and may post a snipet as soon as I get it working.
    Mar 2009
    that would be nice
    http://www.mtskola.com
    May 2008
    Italy
    The best way is the one that Ioannis suggested you in post #9.
    For "HSERIN" instruction you have to use specific pins of your pic micro (you didn't say the type), which are the USART module, plus the DT interrupt routine.
    Serch the forum for DT interrupt to learn more or go to this link: http://www.picbasic.co.uk/forum/showthread.php?t=3251
    XXXXX you can download the project for sms controller at this link:http://techni.caliti.es/blog/2008/12...ontroller.html
    since the project is well documented, you could see the technique used to activate 8 relays or read the status of 8 inputs all via sms command.
    Al.
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. USB Interface using PIC
    Last Post: - 22nd May 2006, 17:04
