Sending Commands from Visual Basic about IR to Pic
Results 1 to 5 of 5
    I would suggest you try to send data to your PC to a terminal software first (Hyperterm, MicroCode Serial communicator or whatever else).
    Then from your PC to your PIC.
    I you have good results, then move on VB. I had some bad experiments in the past on some computer on low baudrate.
    High likely, you're using the internal OSC of your PIC? Don't forget at least the OSCCAL_1K define. Not a bad idea to use DEBUG/DEBUGIN as well. It perform better on some case.
    Use current limiting resistor & the InvertedMode on the PIC side, and it should work on small distance between your PIC and the PC.
    On VB side, I would suggest you to use ReadLine. To use it, you'll need to modify your PIC code to send a LF character (10) at the end.
    Feb 2009
    Southern California
    I think the problem is with "1" vs 1 (SOH)
    [HTML]My PBP Code for sender
    SEROUT led5,12,["9999",1]
    PAUSE 100
    SEROUT led5,12,["9999",5]
    PAUSE 100
    GOTO main
    With this PBP Code it works regarding Pic to Pic communication.
    But if I send "99991" or "99995" by my Visual Basic programm it does not work. [/HTML]
    Your pic is sending out hex 1 and your vb is sending out hex 31
    To get vb to send out a 1 try
    txtDatatoSend.txt = "9999" & chr(1)
    this will add a 1 to it, though if you ever want to send 0 it will actually be sending nul characters
    On the other hand you could send a "1" and on the pic side once you receive your dat variable, just subtract "0" from it to give you the value you want or change your if statements to check for "1"
    Apr 2009
    Arrow
    Hi Sougata
    needed a bit of help on inverters using pic16f72
    read ur posts on the following thread
    http://www.letbasic.com/forum/showth...?t=1846&page=4
    this thread is a year or more old so i believe u have advanced ur inverter quite a lot
    can u help on pic 16f72 code as i'm very bad on coding weras i ve pretty gud hardware knowledge.......
    sam
    [email protected]
  1. Basic PIC circuit acting weird
    By FIONEX in forum General
    Last Post: - 9th October 2008, 01:04
  2. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 07:14
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 04:07
  5. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 13:07
