Parallel Transistors?
Results 1 to 7 of 7
    Jun 2005
    West Australia
    Oops! Wrong information.
    Like all semiconductors Mosfets also have a negative temperature coefficient NOT positive like I mentioned previously. But they still tend to shut down as temperature rises and therefore current share better than bipolar transistors.
    Cheers,
    Bill
    New Zealand
    But still - are FETs as easy to control in a current regulation situation? Also - are there many that can dissipate over 100W of power? I've never used a FET before to limit current and am not really sure how easy it would be to get a good steady current regulation from one.
    I was thinking - what if I use a length of copper wire say 0.1 Ohm from each of the emmiters, the copper would naturally increase it's resistance as it gets hot and let less power through the transistor - so then it would have a semi dynamic leveling system rather than just a static resistor?
    Jun 2005
    West Australia
    Hi George, members.
    Mosfets are capable of big power, no problem, obviously heat sinking is a factor. I would be careful using pcb tracks as a resistor where you are relying on heat as an aid in resistance changing - there is a fine line (no pun intended) between getting hot enough and a fuse, but if you decide to do this see Roman Black's site
    http://www.romanblack.com/pcbtemp.htm
    for a utility to allow calculating track sizes.
    I have had good success with an arrangement that controls Source current by robbing Gate drive. Use a Source resistor (N channel device) to ground and place the b-e junction of an NPN bipolar across it. The collector goes to Gate with a 1k. This will rapidly switch so the average Source current is controlled by the Source resistor - value determined by 0.65/desired current e.g. 0.065 ohms will give 10amps average.
    If this meets your needs I would start small and scale up accordingly.
    I hope this helps.
    Bill
  1. parallel port interfacing - 16f84
    By devil6600 in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2008, 13:18
  2. serial in parallel out using PIC
    By daxki in forum mel PIC BASIC Pro
    Last Post: - 5th April 2007, 02:06
  3. resistor in parallel with a thermistor
    By Pic_User in forum General
    Last Post: - 13th March 2007, 02:42
  4. Help with a Parallel I/O to Machine Interface?
    By john meiers in forum mel PIC BASIC Pro
    Last Post: - 16th September 2005, 19:50
  5. parallel port multi pic programmer?
    By SuB-ZeRo in forum Schematics
    Last Post: - 25th June 2005, 11:20
