Hex editor
Results 1 to 9 of 9
Thread: Hex editor
    Sep 2003
    Vermont
    Default Hex editor
    Is there a simple windows based hex editor for looking at .bmp files on disk that someone could reccomend?
    I need it to find where the image data begins in a file, either on hard disk or an SD card. Freeware would be good!
    Ron
    Sep 2003
    Vermont
    Thanks Steve,
    I'm just dubbing now and I hate to invest substantially in a piece of software for a project that may have no practical application.
    Ron
    Sep 2003
    Vermont
    I bought the Hex workshop. It is inexpensive, and should be bug free.
    Ron
    GOOD! Smart choice!
    I use it often to edit/create Text EEPROMs. Easy to figure out how your LCD scren (of any type) will looks like.
    Sep 2003
    Vermont
    The only issue is there seems to be a lot of data bytes that appear to do nothing before the image file. I need to find the file format to find out what it all does!
    Well, the first link i've posted was for an old BMP format i think, sure there's other info on much recent format such as 24, 32 bits one somewhere.
    T.Jackson's Avatar
    T.Jackson Guest
    Post Psc
    You should be able to find some info a long with source code on PSC that explains the file structure of a Bitmap. I don't think the format of them is terribly
    complex, nothing anywhere near as difficult as a jpeg or animated gif. Happy searching! http://www.planetsourcecode.com
    Post BMP format
    Here is a link for the BMP format..
    http://www.odec.ca/projects/2004/chi...mpresearch.htm
    Anyone have any ideas for code to extract the pixel data? I would suspect it to be something like open the .BMP for read, then open an ASCII file for write, and then stream the data through the PIC...
    I have an application coming up where I need to determine the randomness of dots in a balck and white BMP image. I'll post anything I come up with here... stay tuned
    Bron
    The less you expect, the more you get.
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Configuration bits in a HEX file gone missing?
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2010, 01:10
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  4. Hex Editor for EEPROM
    By exelanoz in forum General
    Last Post: - 21st March 2007, 16:03
  5. Nice and Simple Hex Editor
    By picnaut in forum General
    Last Post: - 2nd June 2004, 00:21
