Help please with Assembly (PBPro user)
Results 1 to 10 of 10
Threaded View
  1. #2
    I am not so experienced at using assembly, but with the help of Darrel, I have been able to get two microchip asm examples to work. (Thanks Darrel!!!).
    This example looks a little more straight forward, but then they always look easy, don't they?
    First, you should define your variables. This I have always done outside the asm portion.
    ;example:
    T1XHi        VAR byte
    T1XLo       VAR byte
    ..................................etc
    ;When these variable are used inside asm, you add a little "_" on the front of them:
    asm
    ..........  _T1XHi
    ........... _T1XLo
    endasm
    Why don't you start with that, and see how many fewer errors you get. Then post your errors here, and I will try to help you.
  1. Adding PBPro code to an ASM file - how to?
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 19:49
  2. Picbasic Pro Demo assembly errors
    By mikeRho in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 07:41
  3. Assembly Guru : Question
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 20th May 2007, 04:51
  4. from assembly to basic
    By shantanu in forum Off Topic
    Last Post: - 1st February 2007, 15:50
  5. How do you do this in Assembly
    By ice in forum mel PIC BASIC Pro
    Last Post: - 10th May 2005, 07:47
