Cannot get pbp to compile
Results 1 to 10 of 10
    Question
    Finally mpswitch seems to suffer a little bit with the latest release, so it's not a viable option yet (well last time I tried it)... If you only use PBP in MPLAB, there's no real advantage to use the latest 8.20 or 8.30 version.
    Hi, Steve
    No advantage at all ... from MPLAB V 8.15a, It doesn't compile any more !!! ROFL
    NOTE: MPLAB 8.15a is available as a direct download on Melab's site ...
    It compile, but lack most feature, so useless
    For PIC18, you add the linker file, for none 18F you don't use MPASM assembler... yeah that's pain
    I now have the 8.15a version installed and that cured the errors.
    I am now trying to get MCS easyhid to work. I have copied the 18f4550.bal plus most all files from the USB18 folder to my c:\projects folder and am now getting the usual "error:Macro USBNIT? Not found in macro file" together with the other three errors usbservice, usbin, usbout.
    Reading a thread 10409? keymuu had similar problems. Don't think PBPUSB18.MAC is required? As an idea I commented out the line LIBRARY PBPPL18L in the PBP/18f4550.bal file. This gave the following errors:
    Error:No library statement or library parameter
    Error:No library statement or MACRO parameter
    Error:Unable to open file PBPMAC.INC
    I have done a search for PBPMAC.INC but can't find it.
    Any suggestions appreciated-thanks.
  1. PBP v2.60 upgrade: MCSP compile issue
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 20:49
  2. need 18F4550.BAS to compile with PBP?
    By jocovo in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2006, 02:23
  3. 18F2620 compile problems in PBP
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 11:11
  4. Replies: 2
    Last Post: - 10th July 2006, 02:05
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
