Cannot get pbp to compile
Results 1 to 10 of 10
Threaded View
  1. #6
    You can work with MPLAB 8.20 and latest 8.30 but it will have some serious limitations about the debugger MPSIM, not sure for PICKIT 2.
    For PIC18, you need to add the linker file. In your case 18F4550.lkr to your project.
    And then you go to, Project> Build Option > Project PicBasic Pro tab. There you select Use MPASM assembler and Use Linker /COFF debugging. Not much. BUT it will sucks, you can't monitor your variable, but only some PIC registers.
    Not a so easy task to create reliable COFF files.... even if the reference book for it is quite small
    Finally mpswitch seems to suffer a little bit with the latest release, so it's not a viable option yet (well last time I tried it)... If you only use PBP in MPLAB, there's no real advantage to use the latest 8.20 or 8.30 version.
  1. PBP v2.60 upgrade: MCSP compile issue
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 19:49
  2. need 18F4550.BAS to compile with PBP?
    By jocovo in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2006, 01:23
  3. 18F2620 compile problems in PBP
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 10:11
  4. Replies: 2
    Last Post: - 10th July 2006, 01:05
  5. Newby- PBP wont compile for 18F (MPLAB)
