Audio sounds
Results 1 to 7 of 7
Thread: Audio sounds
    New Jersey
    Default Audio sounds
    I'm making a toy and I need at least four different sounds. I looked at a piezo buzzer and they are expensive to put four on the board. I'm not using a PIC so I don't have the option of doing software routines. My thought at this point is to use a 555 with one piezo buzzer to try and make different sounds by adjusting the timing. Is this a good idea? Is there a chip out there that can help me do what I need to do? Maybe get an inexpensive PIC with PWM or DTMF tones? Any advice is greatly appreciated.
    Chris
    Wink
    Have a look to HT 2810/2813/2830/2844 or ISD 14xx or 25xx chips ...
    New Jersey
    Ok, so I got an op-amp and tried it. It pretty much worked like crap. I re-checked all of my connections and they looked good but still nothing.
    So, I took out a 16F676 and when I use the "freqout" command along with a 20MhZ resonator, it worked really good. Then I fed the output to a PNP transistor and it was even louder so I think I will most likely use that approach.
    Here is my dilemma. I took a speaker from one of those Motorola talkabout FRS radios. I want to buy about 10 of those speakers but there are no markings on it. Does anyone know what kind of speaker I should look for? 4ohm, 8ohm....frequency range....power rating?
    Thanks in advance for the help.
    Chris
    I don't think those Motorola ones are fancy, so probably anything in a local overstock place would do.
    If you are using a PIC see PIC iPod wav player
    CD mono quality of wav files for voice or sound.
    May be more than you require though.
    Other compiler.
    Norm
    New Jersey
    Norm
    Yeah, it's much more then I need and way above my level of expertise. However, I may be able to use that audio chip and I will check it out to see how it works. Also, your speaker (LS1), do you have a part number for that?
    Chris
  1. Audio Amplifier
    Last Post: - 20th August 2008, 10:45
  2. PIC Audio
    By toofastdave in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 14:49
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
  4. Audio Level Meter
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 16th November 2006, 09:05
  5. Audio Encoding and playback in a PIC
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 09:56
