MAX232 minumum connections.
Results 1 to 5 of 5
    Hi Jason,
    If you are using the 232 chip you must use the charge pump capacitors (0.1µF or 1µF depending on the chip) no mater how many circuits you are using from the chip.
    If you want a “dirty, cheap” way out, look up the SERIN and SEROUT instructions (or variants of it) in the PBP manual. Only one resistor will do the trick. You just have to change the inverted/noninverted mode depending on your choice instruction to be used.
    I use it all the time in my development stages and some times I leave it in my final version if the serial communication is not a life or death situation.
    HTH
    Nick
    You could use any type of inverter based on NPN transistor or Mosfet.
    In some situation SERIN (or any else bit-banged solutions) are nice, sometimes they're a pain.
    Using the PIC USART have poor and cons. Well, the only 2 small cons I know of are:
    1. it use a dedicated PIC input (oh... big deal )
    2. Not all PIC USART allow you to use only TX or RX for the USART, and the remaining pin for standard I/O.
    Feb 2009
    Curious as to why I need the use of the charge pumps if im not sending anything back to the PC, only reading from. If im not converting "to" rs232, why do I need them, just a need of the chip design? The resistor idea ill give a try, but its nice to look at the whole rs232 voltage swing because of the noisy environment that this project is in.
    The hole idea of RS232 is the voltage swing from ±5 to 12 V for noise immunity.
    To make it more confusing your +5 to 10V is a zero and -5 to 12 V is a 1.
    Most of the RS232 devices will recognize logic levels 0-5V from a TTL source but you do not have the built in logic inverter, so you must ask your PIC to do it for you by setting the Invert mode.
    The resistor solution is simple but your noise immunity is no longer there. You will have to use shielded cables and short runs.
    If you are dealing with a harsh environment you must use the RS232 chip and still limited to relatively short runs (I think 50’ maximum) or go RS485 for fairly longer distances without dealing with charge pumps. The charge pumps in the RS232 chips just generate the ±5 to 12 V and invert your TTL signals so you can use one single 5V supply.
    Nick
  1. PIC and MAX232 in/out
    By The Master in forum Serial
    Last Post: - 29th March 2008, 21:41
  2. lcd with Hserout and a max232 connections? help
    By flipper_md in forum Schematics
    Last Post: - 8th March 2008, 16:06
  3. RS232, max232
    By kutsi in forum General
    Last Post: - 30th May 2007, 07:39
  4. MAX232 and DB9 connecter
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 25th March 2006, 17:02
  5. MAX232 Level Converter
    By HarryK in forum General
    Last Post: - 8th March 2005, 09:25
