SD or MMC card as storage for logging
Results 1 to 18 of 18
    Quote Originally Posted by SOMRU View Post
    Yep thats neat , especially if you are pushed for space.
    The SDFS software in picbasic doesn't require any other hardware though, apart from a socket for the card In my case I recovered one from a broken SD card reader (New ones cost less than £1 !), so it cost me nothing to get basic SD functionality
    Quote Originally Posted by Chris Barron View Post
    And the support from MeLabs can not be beat. A month or so ago I found a problem with APPEND. I am not good enough with FAT16 to fix it myself, so I told Jeff about it and now it is fixed. That is why it is now SDFS3. Where else can you get support like that?
    I have tested SDFS more ways than I can count, even wore a SD card out reading and writing over and over.
    SDFS just plain works.
    Feb 2009
    Southern California
    Out of curiosity how many read/writes do you think you got out of that card. I'm always curious as to how accurate data sheets are for things like that, which I can't actually measure practically.
    David
    Bombay, India
    Could anyone using the SFS3 please enlighten me on the amount of flash/ram it consumes? I cannot check it since I do not have PBPL yet.
    thanks
    thanks
    Here is what I have on a basic setup.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3295&stc=1&d=123865124 3">
    Quote Originally Posted by Luckyborg View Post
    David
    That is a hard question.
    The card that failed was an old 64 MB. Well used to begin with.
    When I first started playing with SDFS I was using a 1 GB card, that is when there was an append problem. I tried several cards as not all manufactures sizes are the same. The append problem was SDFS would not append a file past the sector the file originated in. It would write multiple file though. I got to testing with the 64MB card. The first sector took a beating. Fill the sector, erase or format, bang on the keyboard some more...
    I do not have any idea how many times I did this.
    After Jeff fixed the problem, skimask and I was doing some write speed test. I set up a loop to write 8 bytes, read, append 8 more, read... This particular card was running that loop at 3.55Hz.
    The way I understand it, the MBR is in the first sector, more abuse.
    I think I was about 4 hours into that test before failure.
    In theory it has to be something like 10K writes cycles, and it depends of the brand. But how 10K is 10K... that's another story
    thanks
    The attachment did not attach the last time??
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3297&stc=1&d=123868043 6">
    Bombay, India
    thank you Dave
    Nov 2011
    Default Re: SD or MMC card as storage for logging
    sdfs3.zip
    http://melabs.com/resources/samples.htm
    I searched for the ZIP file but all I found was the PICBasic program. Just wondering if anyone might still have the ZIP version with schematics, text files, etc.Or, is there a newer version available?Can a Caveman really do it?
  1. Replies: 12
    Last Post: - 4th March 2010, 22:20
  2. Picbasic MMC SD : sdfs3.bas
    Last Post: - 27th April 2009, 16:03
  3. SD Card Filesystem like AVRDOS for Atmel
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 15:00
  4. Writing to SD card
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 9th November 2007, 12:23
  5. Read and write to sd card
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 20:47
