Yet another SERIN2 question
Results 1 to 7 of 7
    Default Yet another SERIN2 question
    Howdy
    I've fought this long enough - now am asking for help.
    What I have is a serial LCD backpack with a keypad interface as well. Using a PIC 16F870 . That all works fine.
    Sending serial characters, custom characters, etc to the LCD works fine.
    The problem I have is getting data back from the keypad.
    How it works is a request is sent to the keypad using a SEROUT2 command, ($FE,$1B,) an interrupt is returned, (active low), and after it goes high the key number is returned serially. This all works, I have attached a screen shot of the data transmissions from my logic analyzer.
    What I can't get to work is the SERIN2 to actually get the key value back in.
    As I said, the serial data (byte) is coming back, but the SERIN2 just "hangs", and never brings the data in.(must not see it) I tried using a timeout and label in the SERIN2 statement, but that was counter productive, 'cause the data was not being seen anyway.
    here is a short code segment
    serout2 Tx,84, [$FE,$1B] ' request for key data (code for this backpack)
    pauseus 500
    serin2 Rx,84,[key] ' get the key pressed from keypad buffer
    pauseus 500
    serout2 Tx, 84, [$FE,$0C,1,0,#key] 'display it on LCD line 2, position 1
    key jas been defined as a byte variable
    Tx is PORTC.7 and Rx is PORTC.6
    The interrupt is returned to PORTC.5
    4 Mhz oscillator is defined
    The attached screen shot from my logic analyzer shows the interrupt line, data request, and serial data returned. A decimal "9" is what is returned in this case.
    I've tried several variations of the SERIN2 command ( even tried SERIN with the "modedefs.bas" included )
    Should I be trying to receive the data in an interrupt routine? That does not seem necessary - - -
    Something simple, I'm sure - but I am stumped.
    Ken
    Default Attachment for SERIN2
    can't seem to get this to work . .
    Dec 2006
    WADSWORTH OHIO USA
    Greetings
    How about some code...
    I'm use a system using 9 pics all using serin2/out2
    Note after initiating the read pause for 10ms for the write.
    This cured the universe for us.
    other option is to use a single clock source.
    Thanks !
    SOMRU
    TWE/TFP/EE
    Sorry - I did not attach this correctly
    Ken
    Hi Ken,
    We just saw something like this a month or so ago, and what I learned from that thread is serin2 must have a non numeric character follow the numeric data in order to continue on it's way.<br>
    EDIT: AHAA I found it :http://www.picbasic.co.uk/forum/showthread.php?t=10786
    Default Serin2 problem - figured it out !
    Hi all
    It must have been timing related. I revised the code to :
    serout2 Tx,84, [$FE,$1B] 'Request data from Keypad
    pauseus 100 ' added a short delay
    serin2 Rx,84,10,cont,[key] ' put a Timeout & jump in so the SERIN2 will wait
    ' for a while for the data to come back
    cont: ' label to "jump to" if no data
    pause 50 'Not sure if this is needed, will play with it some
    serout2 Tx, 84, [$FE,$0C,1,0,#key] 'the decimal key value is now displayed
    ' The keypad defaults to 0 if a request
    'is made and no key pressed
    Anyway, now it works great. Learned something in the process too !
    You have 4 open threads for the same problem ! WHY ? Please continue the saga within the original post, otherwise how do we know where to post our ideas as to how to help you.
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 10:47
  2. Getting SERIN2 to work?
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 21:10
  3. SERIN2 digit parsing
    Last Post: - 8th January 2007, 00:15
  4. serin2 question
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2006, 22:28
  5. SERIN2 Question
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2006, 16:43
