multiply oscillators
Results 1 to 9 of 9
    Apr 2009
    Default multiply oscillators
    I want to use 4 osscilators @ 1 pic..
    So I can choose between different oscillatos, (8,12,16,20 MhZ)..
                    @ DEVICE PIC16F628A, MCLR_OFF				'MCLR PIN IS DIGITAL
    		@ DEVICE PIC16F628A, WDT_OFF				'WATCHDOG TIMER OFF
    		@ DEVICE PIC16F628A, INTOSC_OSC_NOCLKOUT	'Internal (INTOSC) oscillator with clock Output
    		TRISA = %00000001				'0 = OUTPUT, 1 = INPUT
    		TRISB = %00000000				'0 = OUTPUT, 1 = INPUT
    		CMCON = %00000111				'COMPARATORS OFF
    		S0				VAR PORTB.0
    		LED				VAR PORTB.2
    		TESTJE			VAR PORTB.1
    		PORTA=0
    		PORTB=0
    		Clear							'ALL BUFFERS 0
    TEST:
    		@ DEVICE PIC16F628A, HS_OSC		'HIGH SPEED OSC
    		LED = 1
    		DEFINE OSC 16
    		TESTJE = 1
    		Pause 1000
    		TESTJE = 0
    		LED = 0
    		DEFINE OSC 20
    		TESTJE = 1
    		Pause 1000
    		TESTJE = 0
    		GoTo TEST
    this is my code so far, but i dont work... any ideas of how to do this?
    Define is only used at compile time to tell the compiler which formula to use to get the right timings ...
    so, what you intend to do hasn't the least chance to work ... what you can do is add a freq variable :
    [code]
    SELECT CASE Freq
    Case 16
    TESTJE = 1
    Pause 4*1000
    TESTJE = 0
    LED = 0
    Case 20
    TESTJE = 1
    Pause 5*1000
    TESTJE = 0
    END SELECT
    But will only EASILY work for simple commands ... ( Not with One Wire, Serial or HPWM ..)
    Now ... surely Darrel has a library "hacking" for that ... at asm level !
    Apr 2009
    [code]
    SELECT CASE Freq
    Case 16
    TESTJE = 1
    Pause 4*1000
    TESTJE = 0
    LED = 0
    Case 20
    TESTJE = 1
    Pause 5*1000
    TESTJE = 0
    END SELECT
    I need it for hpwm..
    Wink
    So, Consider
    if You set HPWM @ 1000 Hz for a default 4Mhz Clock ...
    HPWM will run @ 4000 Hz for Xtal @ 16 Mhz
    .................. @ 5000 Hz for Xtal @ 20 Mhz
    Just correct your HPWM frequencies like that ...
    You also can have a look to Genuine examples that show how to use the PWM modules without using the HPWM command ...
    Sep 2005
    Campbell, CA
    You can actually change the PLL and divider at run time. Probably the best way is to use Darrel Taylor's WriteConfig utility.
    Charles Linquist
    Problem is that it is only valid on 18F.
    Is there any specific reason why you want to use multiple OSC speed at runtime?
  1. several oscillators
    By ozzieB in forum mel PIC BASIC Pro
    Last Post: - 14th April 2009, 10:16
  2. Retrieving 32bit Multiply Result
    Last Post: - 28th January 2008, 16:15
  3. 18F4620 hardware multiply
    By eric180db in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 13:54
  4. Can't multiply by 2!
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 29th October 2004, 15:24
  5. Question about Oscillators
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 17:17
