Help with Pic Delay Pulse code please
Results 1 to 37 of 37
    One step at a time...
    Compile this and ensure your LED blinks on GPIO.1... ensure your LED has a suitable series Resistor...
    	'	PIC Defines
    	@ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    		' System Clock Options (Internal)
    	@ DEVICE pic12F675, WDT_ON
    		' Watchdog Timer
    	@ DEVICE pic12F675, PWRT_ON
    		' Power-On Timer
    	@ DEVICE pic12F675, MCLR_OFF
    		' Master Clear Options (Internal)
    	@ DEVICE pic12F675, BOD_ON
    		' Brown-Out Detect
    	@ DEVICE pic12F675, CPD_OFF
    		' Data Memory Code Protect
    	@ DEVICE pic12F675, PROTECT_OFF
    		' Program Code Protection
    	' Define Hardware
    	InputTrigger var GPIO.5 	' Input normally HIGH, goes LOW to Trigger
    	InputReset var GPIO.2		' Input normally HIGH, goes LOW to RESET
    	OutputLine var GPIO.0 		' Normally HIGH, goes LOW when triggered
    	LED var GPIO.1
    	' Define Variables
    	DelayTick var Byte 		' 100mS Tick Counter
    	MyFlags var byte
    	'	Initialise Hardware
    	TRISIO=%00100100		' Preset I/O
    	CMCON=%00000111	  		' Disable Comparators
    	ANSEL=%00000000 		' Disable ADC
    	DelayTick=100			' Reset Counter
    	MyFlags=0
    	High OutputLine			' Everything Reset
    	'	Main Program Loop
    Loop:
    	Pause 500
    	Toggle LED
    	Goto Loop
    Oct 2007
    Hi Melanie
    Thanks for your reply,
    Yes my led blinks ok.
    Cheers
    Dave...
    Oct 2007
    Hi Melanie
    Just an addon to the above test, which worked fine,,,
    Last year you very kindly drafted me a piece of code for a project that has been working flawlessly,
    I am having problems adding an led command to it, if I add an low led command to it, it locks up when its triggered.
    Any ideas,
    Cheers
    Dave..
    'G7JIQ MICRO LINK REPEATER
    'PIC 12F675
    'Internal RC clock
    ' PIC Defines
    ' Watchdog Timer
    ' Power-On Timer
    ' Brown-Out Detect
    ' Define Hardware
    Led var GPIO.1
    ' Define Variables
    ' Initialise PIC
    Reset:
    DelayTick=0 ' Reset Counter
    high OutputLine ' Everything RESET
    pause 2000
    ' Main Program Loop
    Loop:
    ' Test for RESET
    While InputReset=0 ' Just wait here if RESET
    high OutputLine ' Reset Output
    Wend
    ' Test for Trigger
    If InputTrigger=0 then ' Test for Trigger
    low OutputLine ' Enable Output
    DelayTick=1 ' Arm Counter
    'Goto Loop
    ' Timeout Counter
    If DelayTick>0 then
    DelayTick=DelayTick+1 ' Count Time
    Pause 60 ' Waste 100mS
    If DelayTick>50 then goto Reset
    ' 50 = 5 sec
    ' 100 = 10 sec
    ' origanly set at 201 Reset at 20 Seconds
    Goto Loop
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Making Program Code Space your playground...
  3. Help writing pic program with i/p o/p hold delay
    By g7jiq in forum mel PIC BASIC Pro
    Last Post: - 27th May 2008, 21:58
  4. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
  5. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
