Quote Originally Posted by g7jiq View Post
Hi Chris
My pin out was
InputTrigger var GPIO.0 ' Input normally HIGH, goes LOW to Trigger
Output0 var GPIO.1 ' Normally high, goes low when triggered
Output1 var GPIO.2 ' Normally high, goes low when triggered
You changed it to
InputTrigger var GPIO.5 ' Input normally HIGH, goes LOW to Trigger
InputReset var GPIO.2 ' Input normally HIGH, goes LOW to RESET
OutputLine var GPIO.0 ' Normally HIGH, goes LOW when triggered
Led var GPIO.1
The pinouts in my circuit (GPIO.0 , 1, 2 ) were transposed to ( GPIO.5, 2, 0, 1 )
The i/p and o/p are switched around, the trigger is on GPIO.0 you have it on GPIO.5, this is unused on my i/c, I also don't have a led (but I can add one tho if needed)
Cheers
Confused Dave..
Sorry Dave but, the code I used was the code in your original message, and pin assignements are clearly listed there the same as they were in my reply
' Define Hardware
Led var GPIO.1
The assignments in my reply are the same as in your first message on this thread. I can only think that your copy of the program has either merged together this file with another (Did yiou cut and paste ?) or something else is wrong.
Either way I happy that my reply and your first message use the same pinouts, as you will see when you check for yourself
