Don't know what you're doing... I just breadboarded to test what I wrote and it works as expected. The DelayLED goes out if InputTrigger is constantly ON (solid ON) for 1 Second (that's active pulled LOW). If InputTrigger fluctuates, then DelayLED will be on all the time. You got AC coming down the line into InputTrigger? You forgot you need external Pull-Up's on the InputReset and InputTrigger?
The Delay value is one of the two Constants defined at the start. Change that to change the Timeout.
