INT0 Zero Interrupts
Results 1 to 8 of 8
    Question
    I gotta ask . . . Why do you put the percent sign before the value of your variables? It seems to me you are telling the Variables, ports and registers to read binary, and I suppose as long as you only use zero and one it will work, but it's confusing as all get out. Why not just use 0 and 1 ?
    Feb 2009
    Percent madness... I try to make my variable names start with bt for bit, w for word, l for long. The percents really just remind me they are bits. I totally could ditch them. lol maybe I should.
    Thanks for looking at the file. I can't figure out what I am missing, really hoping someone finds something.
    The chart sec 9.1 shows INT0 port latch as 1 not zero when INT0 enabled. Other than that I see nothing, but I am really sleepy right now Doggone PBP interrupts, it doesn't take much for them not to work . . . You might try commenting out the parts that do work until you hit the right formula . . .
    Feb 2009
    Anybody pick up anything else? I feel really frustrated with this interrupt. I think I will try pulling out everything but that interrupt as Joe suggested. Just hoping that maybe the order or bit is wrong in one of the registers.
    Feb 2009
    Thanks for your replies Joe S.
    I figured out the problem. My ADCON1 should have been:
    ADCON1 = %00011111 ' Set all to digital
    Thanks Again,
    Nemesis
    Dec 2007
    Finland
    Post
    After INT0 interrupt you are not clearing INT0IF variable. I don't know does it make difference or not, but add
    INT0IF = 0
    before last ENDIF in INT0 interrupt section.
    Also TMR0 comment is not valid. It should be ON
    INTCON =  %10110000 ' Global, TMR0 off, INT0 ON
    BR,
    -Gusse-
    Feb 2009
    Will do thanks Gussee. Sometimes I am victim of my own cut and paste. Thanks again all.
    -Nemesis
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 06:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
