PIC12F675 not working
Results 1 to 6 of 6
    Jan 2006
    New Hampshire, USA
    Default PIC12F675 not working
    I have use this configuration before with no problem, I don't know what is wrong. GPIO.0 never goes high.
    REM DEVICE = 12F675
    CMCON = 7 'SETS DIGITAL MODE
    ANSEL = 0 'GPIO.0 TO GPIO.3 SET AS DIGITAL
    OPTION_REG = 0 'WEAK PULLUPS ENABLED
    TRISIO = %00001100 'GPIO.2 AND GPIO.3 SET AS INPUT
    VRCON.7 = 0 'TURN OFF VOLTAGE REFERENCE
    'CONDITIONS: INTERNAL OSC CLOCK OUT, WDT DISABLED, PWR UP TIMER DISABLED,
    'MCLR FUNCTION: INPUT PIN, BROWN OUT RESET DISABLED, NO PROTECTION
    DEFINE OSCCAL_1K 1 'SAVES OSCILLATOR CALIBRATION
    START:
    HIGH GPIO.0
    PAUSE 100
    LOW GPIO.0
    PAUSE 100
    IF NOT GPIO.2 AND NOT GPIO.3 THEN START 'IF BOTH ARE LOW, THEN LOOP
    LOW GPIO.0
    PAUSE 500
    IF GPIO.2 OR GPIO.3 THEN HIGH GPIO.0 'ENERGIZE RELAY
    IF NOT GPIO.2 AND NOT GPIO.3 THEN DELAY
    GOTO START
    DELAY:
    PAUSE 2000 '2 SECONDS
    LOW GPIO.0 'DE-ENERGIZE RELAY
    GOTO START
    Looks like a faulty device, bad hardware (socket/breadboard) or device programmer issue to me.
    Assuming the chip is all right, check if your osccal value has been inadvertently erased.
    Anand
    Hi Russ,
    You have not included any config statement, check your 12F675.inc file to make sure you have not commented them out. I am thinking maybe you have none going into your code.
    Talking Detail
    Hi, Russ
    WPU register settings are missing .... WHICH inputs must be pulled up ???
    Jan 2006
    New Hampshire, USA
    Thanks for your insight, I pulled the mosfet that was being driven and now the IC works. The mosfet was shorted.
  1. PIC12F675 problem with port 5
    By NL2TTL in forum mel PIC BASIC
    Last Post: - 5th June 2009, 01:23
  2. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  3. PIC12F675 trouble
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 18:40
  4. Erratic PIC12F675 behavior
    Last Post: - 27th February 2006, 14:46
  5. Input not working with PIC12F675
    By Henque19 in forum mel PIC BASIC Pro
    Last Post: - 15th January 2006, 11:27
