Interrupts
Results 1 to 13 of 13
Thread: Interrupts
    Jul 2007
    Default Interrupts
    I'm trying to understand interrupts.
    What is the difference between an interrupt and just a gosub statement
    below is an example i found on the melabs website.
    what action triggers the interupt.
    ' On Interrupt - Interrupts in BASIC
    ' Turn LED on. Interrupt on PORTB.0 (INTE) turns LED off.
    ' Program waits .5 seconds and turns LED back on.
    led var PORTB.7
    OPTION_REG = $7f ' Enable PORTB pullups
    On Interrupt Goto myint ' Define interrupt handler
    INTCON = $90 ' Enable INTE interrupt
    loop: High led ' Turn LED on
    Goto loop ' Do it forever
    ' Interrupt handler
    Disable ' No interrupts past this point
    myint: Low led ' If we get here, turn LED off
    Pause 500 ' Wait .5 seconds
    INTCON.1 = 0 ' Clear interrupt flag
    Resume ' Return to main program
    Enable
    Bombay, India
    Imagine you sitting at your desktop PC. Imagine you checking your inbox every now and then. It would involve you logging into your account, checking, etc. This is how you would do it if you gosub. Now, imagine for a moment, you have installed a widget like Yahoo messenger which tells you when you have received an email. This is similar to an interrupt. It lets you attend to your business without having to keep repeatedly checking your inbox.
    Interrupts are triggered by events(in the case above, receipt of mail).
    In the example you cited, the interrupt is triggered by the RB0 pin of the controller.
    Once you understand On interrupt goto, look up Darrel Taylor's wonderful Instant Interrupts. I'm not good at linking threads, so please search it. It is much more powerful than the PBP ON INTERRUPT statement
    Jul 2007
    Thanks for your reply
    Wouldn't the microcontroller have to constantly keep looking for the event to trigger the interupt?
    and which part of that code tells you the interrupt is triggered by RB0
    Dan
    Feb 2004
    Michigan, USA
    Using Darrels Instant Interupts, whats the fastest theoretical responce to an interupt using an 18F at 8MHz?
    I have several applications lined up that need less than 50uS responce times.
    Quote Originally Posted by -Dan- View Post
    Dan
    Hi Dan,
    Real interrupts are like your alarm clock in the morning, You might like to ignore but it doesn't take no for an answer, Real interrupts will INTERRUPT whatever the pic is doing and perform the code specified, and no the other code doesn't have to keep checking. THAT SAID, PBP does not have REAL interrupts. ON INTERRUPT sets a flag on the stack and continues the command that was executing and then jumps to the interrupt routine. If you want real interrupts you must either use assembler or Darrel's Instant Interrupt routine.
    <br> INTCON and OPTION_REG are used to control the interrupts and whether they occur on rising or falling edge.
    Jul 2007
    Hi Dan,
    Hi Joe,
    thanks i get the general idea now, but how does the pic know that the event which should trigger the interupt has happened if it isn't looking for it.
    in the little code example i posted it says:
    i understand that it would jump to an interrupt handler call myint but there are no parameters specified as to when it should jump to the interrupt handler, this is what i'm finding confusing.
    Bombay, India
    The PIC knows that an interrupt has occurred when
    1. the event is triggered by hardware and sets a flag inside the PIC silicon
    2. If you have the interrupts enabled and have a service routine for it, the moment the event occurs, the interrupt service routine (ISR) will service it and return back to what it was doing at that point in time.
    3. The RB0 pin is also called INTE pin and is the one that triggers the event in your code.
    4. This is the line that enables the INTE and GIE bits in the interrupt register telling the PIC whether to handle the interrupt in code when it happens
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 06:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
