Interrupts
Results 1 to 13 of 13
Thread: Interrupts
    Jul 2007
    Default Interrupts
    I'm trying to understand interrupts.
    What is the difference between an interrupt and just a gosub statement
    below is an example i found on the melabs website.
    what action triggers the interupt.
    ' On Interrupt - Interrupts in BASIC
    ' Turn LED on. Interrupt on PORTB.0 (INTE) turns LED off.
    ' Program waits .5 seconds and turns LED back on.
    led var PORTB.7
    OPTION_REG = $7f ' Enable PORTB pullups
    On Interrupt Goto myint ' Define interrupt handler
    INTCON = $90 ' Enable INTE interrupt
    loop: High led ' Turn LED on
    Goto loop ' Do it forever
    ' Interrupt handler
    Disable ' No interrupts past this point
    myint: Low led ' If we get here, turn LED off
    Pause 500 ' Wait .5 seconds
    INTCON.1 = 0 ' Clear interrupt flag
    Resume ' Return to main program
    Enable
    Bombay, India
    Imagine you sitting at your desktop PC. Imagine you checking your inbox every now and then. It would involve you logging into your account, checking, etc. This is how you would do it if you gosub. Now, imagine for a moment, you have installed a widget like Yahoo messenger which tells you when you have received an email. This is similar to an interrupt. It lets you attend to your business without having to keep repeatedly checking your inbox.
    Interrupts are triggered by events(in the case above, receipt of mail).
    In the example you cited, the interrupt is triggered by the RB0 pin of the controller.
    Once you understand On interrupt goto, look up Darrel Taylor's wonderful Instant Interrupts. I'm not good at linking threads, so please search it. It is much more powerful than the PBP ON INTERRUPT statement
    Jul 2007
    Quote Originally Posted by Jerson View Post
    Thanks for your reply
    Wouldn't the microcontroller have to constantly keep looking for the event to trigger the interupt?
    and which part of that code tells you the interrupt is triggered by RB0
    Dan
    Feb 2004
    Michigan, USA
    Using Darrels Instant Interupts, whats the fastest theoretical responce to an interupt using an 18F at 8MHz?
    I have several applications lined up that need less than 50uS responce times.
    Quote Originally Posted by -Dan- View Post
    Dan
    Hi Dan,
    Real interrupts are like your alarm clock in the morning, You might like to ignore but it doesn't take no for an answer, Real interrupts will INTERRUPT whatever the pic is doing and perform the code specified, and no the other code doesn't have to keep checking. THAT SAID, PBP does not have REAL interrupts. ON INTERRUPT sets a flag on the stack and continues the command that was executing and then jumps to the interrupt routine. If you want real interrupts you must either use assembler or Darrel's Instant Interrupt routine.
    <br> INTCON and OPTION_REG are used to control the interrupts and whether they occur on rising or falling edge.
    Jul 2007
    Quote Originally Posted by Joe S. View Post
    Hi Dan,
    Hi Joe,
    thanks i get the general idea now, but how does the pic know that the event which should trigger the interupt has happened if it isn't looking for it.
    in the little code example i posted it says:
    i understand that it would jump to an interrupt handler call myint but there are no parameters specified as to when it should jump to the interrupt handler, this is what i'm finding confusing.
    Bombay, India
    The PIC knows that an interrupt has occurred when
    1. the event is triggered by hardware and sets a flag inside the PIC silicon
    2. If you have the interrupts enabled and have a service routine for it, the moment the event occurs, the interrupt service routine (ISR) will service it and return back to what it was doing at that point in time.
    3. The RB0 pin is also called INTE pin and is the one that triggers the event in your code.
    4. This is the line that enables the INTE and GIE bits in the interrupt register telling the PIC whether to handle the interrupt in code when it happens
    Jul 2007
    Ohhh i see its triggered by hardware not software
    Thank you Jerson for helping me understand
    Oct 2008
    Southern California
    Interrupts are something like, if you touch a hot stove, the sensor in your hand detects "something's wrong". That signal goes to a specific location in the brain and causes a muscle action to happen. You don't think about it - it just happens. No matter what you WERE doing before, your hand is going to yank back NOW! You'll then go back to what you were doing before you touched the hot stove.
    More technically speaking, when a hardware interrupt is enabled, and one occurs, the hardware gates in the PIC direct the program pointer to a specific location in memory where the interrupt subroutine's address is stored. The program pointer gets the address of the interrupt service routine and then goes there to handle the interrupt. Once the interrupt handling routine (that you wrote) is done, then the program goes back to where it was based on what it was doing at the time of the interrupt.
    Example: You were blinking an LED on Port A.0. All is well. In your program you configured the Port B.0 pin for interrupt on low-to-high transition and enable the Port B.0 interrupt. Then you pushed a button that connects 5v to Port B.0. The blink portion of the program is stopped, and the chip's internal program pointer goes to the interrupt location in memory and looks for the address of your interrupt handler, and goes there. Once it gets to the end of that routine, then action resumes in the main program (blinking the A.0 LED) where it left off before the interrupt occured.
    You can do this via two methods - PBP or DT INTS. It really depends on how fast you want to handle the interrupt and how much you want to "do it the right way", I guess. In other languages and chips, I've always used hardware interrupts and prefer to handle them as fast as possible and with as little impact on the running program as possible. Often times the interrupt is something that's just plain boring or bothersome like an input character from a USART, a counter rolling over, a timer rollover, odometer tic, etc. Nothing you really want to redirect the main program over, but something that still needs to be addressed and then move on back to what you were doing before. Interrupts using DT INTS is the fastest way, and probably (technically) the right way to handle PIC interrupts while using PBP as your language. I strongly suggest learning more about interrupts at the hardware level (RTFM) before you attempt DT INTS. While Dave's documentation is good, it assumes you know what/how/why interrupt in the first place. Not a good place for a newbie to go off exploring without some guidance.
    Hope this helped,
    rswain
    OK lets beat this subject into shim stock . . . INTERRUPTS are TRIGGERED by hardware events, They are handled by software. Assembly will start working on the interrupt within 2 to 4 cycles of the Oscillater. PBP On Interrupt, puts a pointer on the stack, like it does with a subroutine, and executes it right after it finishes what it is doing.
    Consider this:
    start:
    on interrupt goto Emergency<font color=red><b>_</b></font color>stop  ':D thanks mister_e
    PortB.3 = 1 ' motor runs for 1 minute, stops for 1 minute
    pause 60000
    PortB.1 = 0
    Pause 60000
    Emergency_Stop:
    PortB.3 = 0
    sleep
    In the example above ASM interrupts will shut the motor off right now, PBP might have you wait 59 seconds
    and in the example above, there's an underscore missing
    Mar 2009
    Big thanks to you all
    -Dan-
    Jerson
    jmgelba
    Joe S. --- Oh those funny days N. Khouroutchouv and others
    rswain
    mister_e
    Greetings from Algeria.
    Mar 2009
    Question:
    Did anyone manage to get a working PicBasic pro + Microstudio + wine under Debian GNU/linux_lenny.
    Thanks in advance.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 06:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
