Thanks to the excellent advice from you guys, I modified the code and it now works in the form shown below. Notice I also changed the processing epoch of the COUNT loop and reduced the Pause, because of one of your comments. With this sampling rate of the sensor pulse input rate I shouldn't miss any events. Even if I miss a couple, this resolution will adequately support the application.
I am also going to continue to use WORD rather than BYTE for the variables since the production version may encounter more than 256 events during the combined epochs.
When I finally understood from your comments that WRITE was overwriting the EEPROM address that I was using to see if the indexer was indexing with a HighByte that was continuously zero, I was able to solve the problem. Actually, the indexer statement was working....I just couldn't see that it was by the way I was trying to monitor it.
Can't tell you all enough how much I appreciate your help in resolving this problem! As a long term Visual Basic programmer, my faith in PBP is restored!
Code:'Registers Settings TRISA = 0 ' Set PORTA pins to outputs TRISB = 0 ' Set all PORTB and PORTC pins to outputs TRISC = 0 ANSEL = 0 ' Set all pins to digital ANSELH = 0 PORTC = 0 ' Preset LEDs off TRISA.1 =1 ' Set RA1 as input port for meter pulse inputs 'Variables Initialization switchstate var bit ' Stores value of last measured switchstate k CON 60 ' Calibration factor for flow meter...# pulses per gal i VAR WORD ' Index used in Gallon counter Repeat...Until loop C1 VAR WORD ' Storage variable for count from COUNTER 'Start...normal code here MAIN: 'Send PWM pulse to latching solenoid to open valve 'Generates 10 millisec pulse on RC3 output pin LOW PORTC.3 ' Initialize output pulse polarity PULSOUT PORTC.3,1000 ' Generate 10 msec pulse to RC3 ' Valve should be open at this point and water flowing ' Start measuring output of flow meter at RA1 input pin C1 = 0 ' Initialize pulse count variable to zero i = 0 ' Initialize total pulse count index to zero REPEAT ' Assume it takes k accumulated pulses for required gallons ' Count the number of pulses from Hall Effect Magnetic Sensor in 5 sec ' epochs and add count from each epoch to total accumulation and then ' shutoff the valve when count meets i>k criteria. Count PORTA.1,5000,C1 'WRITE 5,C1.HighByte ' Write count into EEPROM location 5,6 during 'WRITE 6,C1.LowByte ' pre-production testing 'Slowly blink LED during water flow HIGH PORTC.0 ' If we get here, Blink the LED once PAUSE 100 LOW PORTC.0 i = i + C1 ' Add count to total pulse accumulation indexer 'When i >= k, required gallons have flowed by the meter UNTIL i > k 'WRITE 7,i.HighByte 'Store result as test of code..not in production 'Write 8,i.LowByte GoTo ShutValve ShutValve: 'Send PWM pulse to latching solenoid to close valve PULSOUT PORTC.3,1000 ' Generate required 10 msec pulse to RC3 ' Valve should be closed at this point and no water flowing ' Put code here to test if flow meter has stopped as an indication that ' no water is flowing...is a double check on valve closure. C1 = 0 ' Reset pulse counter to zero Count PORTA.1,10000,C1 ' Collect meter pulse input, if any, for 10 secs IF C1 > 0 Then ' Water is still flowing...close the valve! PULSOUT PORTC.3,1000 ' Command valve solenoid to close ENDIF ' Put code here to put Microcontroller back to Sleep State to wait for ' next Interrupt SLEEP = 65,535 END
