Indexer not indexing...a basic PBP problem??
Results 1 to 9 of 9
    Bombay, India
    Hi Joe
    The initial write is to locations 7 and 8. The write inside the while loop is to 8,9. So, the location that I assume he's looking at is 7 this obviously wouldn't change from 0.
    Hi Joe
    Hi Jerson, I get that, if you store your lawnmower in your own garage, looking next door will likely not find it. I am curious though, his statement :
    WRITE 5,C1.Byte0 ' Write count into EEPROM location 5,6 for post-run count test
    WRITE 6,C1.Byte1
    is this valid in PBP ? And my second question pertains to his declaring i as WORD, Wouldn't he write it as var.lowbyte ?
    Mar 2009
    Colorado
    Thumbs up Indexeer not indexing
    Thanks to the excellent advice from you guys, I modified the code and it now works in the form shown below. Notice I also changed the processing epoch of the COUNT loop and reduced the Pause, because of one of your comments. With this sampling rate of the sensor pulse input rate I shouldn't miss any events. Even if I miss a couple, this resolution will adequately support the application.
    I am also going to continue to use WORD rather than BYTE for the variables since the production version may encounter more than 256 events during the combined epochs.
    When I finally understood from your comments that WRITE was overwriting the EEPROM address that I was using to see if the indexer was indexing with a HighByte that was continuously zero, I was able to solve the problem. Actually, the indexer statement was working....I just couldn't see that it was by the way I was trying to monitor it.
    Can't tell you all enough how much I appreciate your help in resolving this problem! As a long term Visual Basic programmer, my faith in PBP is restored!
    'Registers Settings
    TRISA = 0           ' Set PORTA pins to outputs
    TRISB = 0           ' Set all PORTB and PORTC pins to outputs
    TRISC = 0
    ANSEL = 0           ' Set all pins to digital
    ANSELH = 0
    PORTC = 0			' Preset LEDs off
    TRISA.1 =1          ' Set RA1 as input port for meter pulse inputs
    'Variables Initialization
     switchstate   var bit ' Stores value of last measured switchstate
     k             CON 60  ' Calibration factor for flow meter...# pulses per gal
     i             VAR WORD    ' Index used in Gallon counter Repeat...Until loop
     C1            VAR WORD    ' Storage variable for count from COUNTER
    'Start...normal code here
    MAIN:
          'Send PWM pulse to latching solenoid to open valve
            'Generates 10 millisec pulse on RC3 output pin
             LOW PORTC.3            ' Initialize output pulse polarity
             PULSOUT PORTC.3,1000   ' Generate 10 msec pulse to RC3
        ' Valve should be open at this point and water flowing
        ' Start measuring output of flow meter at RA1 input pin
        C1 = 0           ' Initialize pulse count variable to zero
        i = 0            ' Initialize total pulse count index to zero
        REPEAT ' Assume it takes k accumulated pulses for required gallons
            ' Count the number of pulses from Hall Effect Magnetic Sensor in 5 sec
            ' epochs and add count from each epoch to total accumulation and then
            ' shutoff the valve when count meets i>k criteria.
            Count PORTA.1,5000,C1
            'WRITE 5,C1.HighByte    ' Write count into EEPROM location 5,6 during
            'WRITE 6,C1.LowByte     ' pre-production testing
             'Slowly blink LED during water flow
               HIGH PORTC.0         ' If we get here, Blink the LED once
               PAUSE 100
               LOW PORTC.0
            i = i + C1              ' Add count to total pulse accumulation indexer
         'When i >= k, required gallons have flowed by the meter
         UNTIL i > k
         'WRITE 7,i.HighByte   'Store result as test of code..not in production
         'Write 8,i.LowByte
         GoTo ShutValve
    ShutValve: 'Send PWM pulse to latching solenoid to close valve
                PULSOUT PORTC.3,1000   ' Generate required 10 msec pulse to RC3
        ' Valve should be closed at this point and no water flowing
        ' Put code here to test if flow meter has stopped as an indication that
        ' no water is flowing...is a double check on valve closure.
            C1 = 0                 ' Reset pulse counter to zero
            Count PORTA.1,10000,C1 ' Collect meter pulse input, if any, for 10 secs
            IF C1 > 0 Then
                ' Water is still flowing...close the valve!
                PULSOUT PORTC.3,1000   ' Command valve solenoid to close
        ' Put code here to put Microcontroller back to Sleep State to wait for
        ' next Interrupt
            SLEEP = 65,535
    Quote Originally Posted by jellis00 View Post
    'Registers Settings
    TRISC = 0
    ANSELH = 0
    MAIN:
               PAUSE 100
               LOW PORTC.0
         UNTIL i > k
         'Write 8,i.LowByte
         GoTo ShutValve
            IF C1 > 0 Then
        ' next Interrupt
            SLEEP = 65,535
    Hi jellis00,
    My question was, . . . actually, answered in this final cut of your code. Thank You
  1. PBP 2.60 & ADCON1 problem
    By bitbangerbob in forum mel PIC BASIC Pro
    Last Post: - 21st October 2009, 12:06
  2. Loop with two motor and 2 sensors
  3. Big Problem in PBP To receive DMX
    By programmer07 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 18:49
  4. pbp pro versus oshon or bascom basic
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2006, 00:49
  5. Problem DEFINE OSCCAL and PBP 2.46
    By David in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2005, 17:19
