i tried to get an interrupt at .1ms using dt-ints.
i used 16f877a at 4MHz and timer1 1:1 prescaler , want to toggle a led that connected to portb.7 to test interrupt.
timer1 pre-load value is 65437. The signal must be 5KHz , but it is about 2.4KHz.
The code is below.What am i missing or what is the mistake?
Code:INCLUDE "DT_INTS-14.bas" ' Base Interrupt System INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts LED VAR PORTB.7 OUTPUT LED ADCON1 = 7 ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _TMR1_INT, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts T1CON = %00000101 ; Prescaler = 1, TMR1ON TMR1L = $9D ; TMR1 = 65437 TMR1H = $FF MAIN : PAUSE 50 GOTO MAIN TMR1_INT : TMR1L = $9D TMR1H = $FF TOGGLE LED @ INT_RETURN
