flywheel diode
Results 1 to 4 of 4
Thread: flywheel diode
    Default flywheel diode
    I want to ask where I can put the flywheel protection diode across the winding motor or across (D-S) of mosfet and why , beacuse I damaged many mosfets and want to know what is the problem ?
    Jan 2006
    Istanbul
    Check This circuit.
    Quote Originally Posted by iugmoh View Post
    oky I build the same circuit but without the pull down resistor and I add a 7 ohm resistor between the gate driver circuit and mosfet gate. But it's important to add a snubber circuit ?
    The why part..
    Think of an inductive load as an electrical spring. When the electrical pressure is released (turned off ) the current will reverse for a bit. The reverse current is what damages the MOSFET.
  1. Using ICSP and a diode
    Last Post: - 13th January 2009, 18:02
  2. anti ESD?
    Last Post: - 27th August 2008, 15:29
  3. Serin serout problem
    Last Post: - 6th February 2007, 05:25
  4. 7805 regulator + diode
    By DanPBP in forum Off Topic
    Last Post: - 14th June 2006, 21:45
  5. measuring current from a photo diode
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th November 2005, 15:42
