The code is simple and should run with no problems.
If you insist on simulation, I do not know much. I hear that Proteus is the Best, but still have a few flaws.
Did you try the code on real circuit?
Hi Ioannis,
No, I do not have all the parts to try it. That was the reason for using Proteus. I saw a post from you regarding ULN 2083. If I decided to use that instead ULN 2004 what else should I need to modify (software and hardware)?
Gabi
Some of my projects: http://www.youtube.com/user/wellyb00t
After 1 month I finally make that running - simulating properly in Proteus. My problem was that ULN2803. I didn't know that chip invert signal's. After I put some hex inverters 7404 everything running properly.
My question is:
in real life (I will build the real circuit) I need that inverters or everything will run normal without that?
Many thanks
Gabi
Instead of inverters, why don't you invert he data that you output from the PIC?
Instead of inverters, why don't you invert the data that you output from the PIC?
Hi Ioannis,
I try to do that but, I failed. Can you show my how? On the other hand the question it is still: do I need that inverters in a real circuit?
Thank you for your time
Gabi
If your load needs an 1 and you send a 0 then it is obvious that you need an inverter.
But as I said, instead of 1, send 0 in software.
For example,
var_a=%10101010
var_1=var_a XOR %11111111
The result in var_a will be the complement of the initial value.
