Dera sir,
first of all thanks for ur reply..
i'm just a beginner for these field...
i did all hardware for ur scrool temp display..but when i try to convert
(by using MPLAB ide 7.5) ur codes to hex file,i give the path to saved it in C:\out put directory in my pc..
these errors came..what mistake did i do..?pls help
thanks
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F872 "matrix.asm" /l"matrix.lst" /e"matrix.err"
Error[108] C:\OUTPUT\MATRIX.ASM 1 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 2 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 3 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 4 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 5 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 6 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 7 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 8 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 9 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 10 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 11 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 12 : Illegal character (')
Warning[207] C:\OUTPUT\MATRIX.ASM 13 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 13 : Illegal character (0)
Warning[207] C:\OUTPUT\MATRIX.ASM 14 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 14 : Illegal character (5)
Warning[207] C:\OUTPUT\MATRIX.ASM 15 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 15 : Illegal character (1)
Warning[207] C:\OUTPUT\MATRIX.ASM 16 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 16 : Illegal character (1)
Warning[207] C:\OUTPUT\MATRIX.ASM 17 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 17 : Illegal character (2)
Warning[207] C:\OUTPUT\MATRIX.ASM 18 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 18 : Illegal character (2)
Warning[207] C:\OUTPUT\MATRIX.ASM 19 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 19 : Illegal character (3)
Warning[207] C:\OUTPUT\MATRIX.ASM 20 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 20 : Illegal character (3)
Warning[207] C:\OUTPUT\MATRIX.ASM 21 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 21 : Illegal character (4)
Warning[207] C:\OUTPUT\MATRIX.ASM 22 : Found label after column 1. (eeprom)
Error[108] C:\OUTPUT\MATRIX.ASM 22 : Illegal character (4)
Error[122] C:\OUTPUT\MATRIX.ASM 24 : Illegal opcode (ADC_BITS)
Error[122] C:\OUTPUT\MATRIX.ASM 25 : Illegal opcode (ADC_CLOCK)
Error[122] C:\OUTPUT\MATRIX.ASM 26 : Illegal opcode (ADC_SAMPLEUS)
Error[128] C:\OUTPUT\MATRIX.ASM 27 : Missing argument(s)
Error[128] C:\OUTPUT\MATRIX.ASM 28 : Missing argument(s)
Error[128] C:\OUTPUT\MATRIX.ASM 30 : Missing argument(s)
Error[128] C:\OUTPUT\MATRIX.ASM 31 : Missing argument(s)
Error[128] C:\OUTPUT\MATRIX.ASM 32 : Missing argument(s)
Warning[207] C:\OUTPUT\MATRIX.ASM 33 : Found label after column 1. (counter)
Error[122] C:\OUTPUT\MATRIX.ASM 33 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 34 : Found label after column 1. (scan)
Error[122] C:\OUTPUT\MATRIX.ASM 34 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 35 : Found label after column 1. (scroll)
Error[122] C:\OUTPUT\MATRIX.ASM 35 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 36 : Found label after column 1. (leddata)
Error[122] C:\OUTPUT\MATRIX.ASM 36 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 37 : Found label after column 1. (temp)
Error[122] C:\OUTPUT\MATRIX.ASM 37 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 38 : Found label after column 1. (tempA)
Error[122] C:\OUTPUT\MATRIX.ASM 38 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 39 : Found label after column 1. (tempB)
Error[122] C:\OUTPUT\MATRIX.ASM 39 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 40 : Found label after column 1. (tempC)
Error[122] C:\OUTPUT\MATRIX.ASM 40 : Illegal opcode (var)
Warning[207] C:\OUTPUT\MATRIX.ASM 42 : Found label after column 1. (CLEAR)
Error[108] C:\OUTPUT\MATRIX.ASM 42 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 44 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 45 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 46 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 47 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 48 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 49 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 50 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 51 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 52 : Illegal character (')
Error[108] C:\OUTPUT\MATRIX.ASM 53 : Illegal character (')
Warning[207] C:\OUTPUT\MATRIX.ASM 55 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 55 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 56 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 56 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 58 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 58 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 59 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 59 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 60 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 60 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 61 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 61 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 62 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 62 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 63 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 63 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 65 : Found label after column 1. (ADCIN)
Error[108] C:\OUTPUT\MATRIX.ASM 65 : Illegal character (0)
Warning[207] C:\OUTPUT\MATRIX.ASM 66 : Found label after column 1. (temp)
Error[113] C:\OUTPUT\MATRIX.ASM 66 : Symbol not previously defined (temp)
Warning[209] C:\OUTPUT\MATRIX.ASM 66 : Missing quote
Error[124] C:\OUTPUT\MATRIX.ASM 66 : Illegal argument (expected single character)
Error[112] C:\OUTPUT\MATRIX.ASM 66 : Missing operator
Warning[207] C:\OUTPUT\MATRIX.ASM 67 : Found label after column 1. (temp)
Warning[207] C:\OUTPUT\MATRIX.ASM 69 : Found label after column 1. (tempA)
Error[113] C:\OUTPUT\MATRIX.ASM 69 : Symbol not previously defined (DIG)
Error[112] C:\OUTPUT\MATRIX.ASM 69 : Missing operator
Warning[207] C:\OUTPUT\MATRIX.ASM 70 : Found label after column 1. (tempB)
Error[113] C:\OUTPUT\MATRIX.ASM 70 : Symbol not previously defined (DIG)
Error[112] C:\OUTPUT\MATRIX.ASM 70 : Missing operator
Warning[207] C:\OUTPUT\MATRIX.ASM 71 : Found label after column 1. (tempC)
Error[113] C:\OUTPUT\MATRIX.ASM 71 : Symbol not previously defined (DIG)
Error[112] C:\OUTPUT\MATRIX.ASM 71 : Missing operator
Error[108] C:\OUTPUT\MATRIX.ASM 73 : Illegal character (=)
Warning[207] C:\OUTPUT\MATRIX.ASM 76 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 76 : Illegal opcode (counter)
Warning[207] C:\OUTPUT\MATRIX.ASM 77 : Found label after column 1. (READ)
Error[122] C:\OUTPUT\MATRIX.ASM 77 : Illegal opcode (tempA)
Warning[207] C:\OUTPUT\MATRIX.ASM 78 : Found label after column 1. (NEXT)
Error[122] C:\OUTPUT\MATRIX.ASM 78 : Illegal opcode (counter)
Warning[207] C:\OUTPUT\MATRIX.ASM 80 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 80 : Illegal opcode (counter)
Warning[207] C:\OUTPUT\MATRIX.ASM 81 : Found label after column 1. (READ)
Error[122] C:\OUTPUT\MATRIX.ASM 81 : Illegal opcode (tempB)
Warning[207] C:\OUTPUT\MATRIX.ASM 82 : Found label after column 1. (NEXT)
Warning[207] C:\OUTPUT\MATRIX.ASM 83 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 83 : Illegal opcode (counter)
Warning[207] C:\OUTPUT\MATRIX.ASM 84 : Found label after column 1. (READ)
Error[122] C:\OUTPUT\MATRIX.ASM 84 : Illegal opcode (tempC)
Warning[207] C:\OUTPUT\MATRIX.ASM 85 : Found label after column 1. (NEXT)
Warning[207] C:\OUTPUT\MATRIX.ASM 91 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 91 : Illegal opcode (scroll)
Warning[207] C:\OUTPUT\MATRIX.ASM 92 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 92 : Illegal opcode (scan)
Warning[207] C:\OUTPUT\MATRIX.ASM 93 : Found label after column 1. (PORTC)
Warning[207] C:\OUTPUT\MATRIX.ASM 94 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 94 : Illegal opcode (counter)
Warning[207] C:\OUTPUT\MATRIX.ASM 95 : Found label after column 1. (PORTB)
Error[113] C:\OUTPUT\MATRIX.ASM 95 : Symbol not previously defined (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 95 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 96 : Found label after column 1. (PAUSE)
Error[108] C:\OUTPUT\MATRIX.ASM 96 : Illegal character (1)
Warning[207] C:\OUTPUT\MATRIX.ASM 97 : Found label after column 1. (PORTC)
Warning[207] C:\OUTPUT\MATRIX.ASM 98 : Found label after column 1. (NEXT)
Warning[207] C:\OUTPUT\MATRIX.ASM 99 : Found label after column 1. (NEXT)
Warning[207] C:\OUTPUT\MATRIX.ASM 100 : Found label after column 1. (FOR)
Error[122] C:\OUTPUT\MATRIX.ASM 100 : Illegal opcode (counter)
Warning[207] C:\OUTPUT\MATRIX.ASM 101 : Found label after column 1. (leddata)
Error[108] C:\OUTPUT\MATRIX.ASM 101 : Illegal character ([)
Warning[207] C:\OUTPUT\MATRIX.ASM 102 : Found label after column 1. (NEXT)
Warning[207] C:\OUTPUT\MATRIX.ASM 103 : Found label after column 1. (NEXT)
Warning[205] C:\OUTPUT\MATRIX.ASM 105 : Found directive in column 1. (END)
Skipping link step. Not all sources built successfully.
BUILD FAILED: Thu may 3,10.20am
