8x8 Scrolling LED display (Simple example)
Results 1 to 40 of 69
    May 2009
    Wink Matrix clock
    please, it sends the project of the clock and code source.
    Quote Originally Posted by wellyboot View Post
    Hi again, Thanks for your replys, have made a couple of alterations
    1st) I noticed when the digits 1st came onto the display on the right hand side column, the left hand side column some of the LEDs lit very dimmly when they should have been off.
    I have modified the 'LOOP' section of code as follows to fix this problem and speed up the scrolling a bit too.
    LOOP:
    FOR scroll = 0 TO 35
    FOR scan = 0 TO 15
    PORTC = 1
    FOR counter = 0 TO 7
    PORTB = leddata [counter]
    PAUSEUS 1500
    PORTB = 0
    PORTC = PORTC * 2
    NEXT
    NEXT
    FOR counter = 0 TO 34
    leddata [counter] = leddata [counter+1]
    NEXT
    NEXT
    GOTO START
    2) I have improved the look of the characters in the eeprom locations as follows:
    eeprom 0,[%00111110,%01010001,%01001001,%01000101,%00111110] '0
    eeprom 5,[%00000000,%01000010,%01111111,%01000000,%00000000] '1
    eeprom 10,[%01000010,%01100001,%01010001,%01001001,%01000110] '2
    eeprom 15,[%00100001,%01000001,%01000101,%01001011,%00110001] '3
    eeprom 20,[%00011000,%00010100,%00010010,%01111111,%00010000] '4
    eeprom 25,[%00100111,%01000101,%01000101,%01000101,%00111001] '5
    eeprom 30,[%00111100,%01001010,%01001001,%01001001,%00110000] '6
    eeprom 35,[%00000001,%01110001,%00001001,%00000101,%00000011] '7
    eeprom 40,[%00110110,%01001001,%01001001,%01001001,%00110110] '8
    eeprom 45,[%00000110,%01001001,%01001001,%00101001,%00011110] '9
    3) I have noticed that if the LM35 is too close to the PIC IC the output is higher than normal resulting in a higher temperature being displayed, the PIC IC is cold so i have no idea why this is happening. I have soldered my LM35 onto 3 wires about 4cm's from the board which seems to have corrected the problem.
    Hope this covers all the bugs!
    May 2009
    USA
    Wow, that is really cool. I was expecting the source code to be at least a full screen full. Good work, I have this one added to favorites
    Why is the email address verification case sensitive?
    Dec 2009
    Default temperature sensor circuit diagram
    Ma'am/ Sir
    I would like to see your circuit diagram or schematic diagram for your temperature sensor also the source code for this item...
    I'm a newbie in PIC and I would like to use PIC16f877a
    Hope you could help me pls
    Feb 2007
    Hi
    Take a look at the 3rd post for circuit diagram (without LM35 sensor)
    take a look at 5th post for code, and 7th post for modification to code
    also this line (27th) in the code:
    ADCON1 = %10000101 'AN0 ANALOG I/P + right justify result
    needs changing to:
    ADCON1 = %10001110 'AN0 ANALOG I/P + right justify result
    this will set AN0 only to analog and the rest of portA to digital, this where you connect a LM35 temperature sensor output.
    I believe this code should work with a 16F877 aswel but not 100% sure
    baco1978's Avatar
    baco1978 Guest
    i really like the idea of a scrolling temperature display.
    could somebody post the hexfile?
    in the lite version the 16F872 isn't supported
    thanks
    Apr 2010
    dear wellyboot,
    thanks a lot for share this application with the members..
    can u modify it to a scrolling clock or both scrolling clock+thermometer??
    i really need one to built...
    waiting for ur reply
    thanks
    krish69
    Now that i see the circuit again, why not use the 2803 instead of two 2004?
    Apr 2010
    Quote Originally Posted by krish69 View Post
    dear wellyboot,
    thanks
    krish69
    dear wellyboot..
    waiting for ur answer for my request..
    thanks
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 16:23
  3. 5x7 LED Matrix Scrolling Display
    By roycarlson in forum mel PIC BASIC Pro
    Last Post: - 4th August 2008, 23:50
  4. Replies: 2
    Last Post: - 14th July 2008, 22:11
  5. LCD will not start
