Picstart + USB to Serial Convertor
Results 1 to 3 of 3
    Mark Scotford's Avatar
    Mark Scotford Guest
    Default Picstart + USB to Serial Convertor
    I checked the FAQ could not find an answer to this one. Does a Picstart work with a USB to Serial Convertor? My laptop does not have a Serial port and I need to do some work in the field. Is there a USB Picstart? Which convertor worked for you?
    USB to serial adapter are suppose to do the same job as a regular serial port. There's no USB PICSTART. so i figure it's really suppose to work as well.
    usb adapter available :
    melabs http://www.melabs.com/products/accessry.htm.
    SfCable http://www.sfcable.com/Merchant2/mer...ROD/72/UB30-40
    Sewell Direct http://sewelldirect.com/USBtoSerial....ch_type=search
    A search on Google can give you also many other place.
    I use an IOGear USB/Serial converter on an HP ze5300 laptop. It works with the PicStart Plus & MeLabs serial programmers.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  2. Serial data to USB
    By cooksydesign in forum USB
    Last Post: - 29th October 2008, 15:10
  3. USB and serial cable connection(s)
    By ardhuru in forum Schematics
    Last Post: - 18th August 2008, 15:26
  4. Bafo USB to serial adapter
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 29th July 2006, 18:48
  5. Serial to USB converter
    By jrt4fun in forum USB
    Last Post: - 8th August 2005, 15:14
