Using PIC16F84A as a timer for several I/O
Results 1 to 8 of 8
    I know...I am missing something.
    I think he wants to switch the circuit he has from 1 motor to the other so as not to buy / build another tracking circuit. It is doable but the issue I see is when switching from 1 set of sensors to another the calibration difference may throw things out of whack. I think all you need is a simple loop to switch a relay, something like:
    loop:
    PortB.0 = 0
    pause 60000
    portb.0 = 1
    pause 60000
    goto loop
    EDIT: Another issue came to mind, and that is how your tracking circuit will react to having its outputs go from open circuit to loaded
    being switched by a relay, I am thinking some big resistors (high watt high ohm value) joining those circuits to handle the transients, or perhaps MOVs. Better yet use FETs to switch instead of relays . Damn I must be getting old . . .
    WOWWWW guys, i didnt think this would be that complicated.
    Ok let me try to explain once more, u seeeee i already have the tracking circuit made, i got the 2 LDRs (FYI: these LDRs compare the light intensity and then move motor to a postion where there is equal light falling upon them) and the motor running at 12V, everything is setup, basically i have finished the tracking system for azimuth direction.
    All i want to do is thaaat instead of making a whole new tracking circuit for the vertical direction, i want to use an automatic timer. so now i should have one tracking circuit, 2 LDRs for azimuth direction, motor for moving panel in azimuth direction, 2 LDRs for vertical direction, and a motor for vertical direction. All the automatic timer should do is that to switch from one motor and a pair of LDRs (azimuth direction) to the other motor and a pair of LDRs (vertical direction).
    is there any project anywhere of this nature that i can refer to?
    Guys i seriously appreciate all the help u have provided, i mean believe it or not, this was my first time ever posting a message in a forum, and im really glad to see the kind of respose i have recieved.
    thanks once again, any furthur help would be appreciated,
    take care
    OptimusPrime, All you need is a 4 pole double throw relay. 2 contacts for the motor output from the tracker to the motors and 2 contacts for the 2 sets of LDR's. Program the PIC for 60 second pause then toggle 1 of the outputs to drive a transistor to switch the relay... Pretty simple I think...
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 09:41
