Using PIC16F84A as a timer for several I/O
Results 1 to 8 of 8
    Default Using PIC16F84A as a timer for several I/O
    Hello everyone,
    i want to use PIC16F84A as a timer,
    basically im wokring on a sun-tracking system for solar panels which use LDRs to comapre light intensity and motors to move the panel accordingly.
    Now the problem is that i have to move the solar panel in both azimuth and vertical directions, so i was thinking, instead of using two separate circuits for the directions i use a timer circuit instead.
    The timer circuit's function would be to turn on 2 LDRs, and the motor for vertical direction for about 1 minute, and then switches to 2 LDRs and motor for the azimuth direction
    i would appreciate if anyone can help me with this issue, or pls refer me to a project in this forum of the similar nature
    Thank You
    Feb 2003
    Salt Lake City, Utah USA
    ... lots of timer examples in the Example Code Section. See these for example:
    http://www.picbasic.co.uk/forum/showthread.php?t=2129
    http://www.picbasic.co.uk/forum/showthread.php?t=190
    http://www.picbasic.co.uk/forum/showthread.php?t=632
    there are more in that section as well.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Do you really want the device to work on one for a minute and then the other? Or make the adjustment then wait for a minute before the other adjustment is made?
    Start:
    Vertical routine
    pause for 1 minute
    azimuth routine
    pause for 1 minute
    Goto Start
    Start:
    Vertical routine
    pause for 1 minute
    azimuth routine
    pause for 1 minute
    Goto Start
    I just want the device to work on one for a minute and then the other.
    i already have a circuit which does all the tracking and movement of the motor, you see that circuit gets its input from 2 LDRs and then moves the motor in azimuth direction depending on where the sun is.
    Now what i want to do is, instead making a new circuit for the vertical direction, i want to make a timer circuit using PIC16F84A. So, now 2 inputs from the tracker circuit go into the PIC for timer circuit which is then connected to 4 LDRs as outputs (2 for vertical, 2 for azimuth). Two wires (negative, positive) for the motor control coming out from the tracker circuit go into the PIC for timer circuit as inputs, and at the output there will be 4 wires (2 wires for azimuth motor, 2 from vertical motor).
    Sooooo, for the first minute 2 LDRs for azimuth and motor for azimuth turns on, once thats done the trakcer circuit will do all the tracking and motor movement. After the 1 minute 2 LDRs for vertical and motor for vertical turns on... and then continues as a loop
    wowwwww thts looong, sorry for that, any help would be appreciated
    take care
    What about this, if I am following you.
    All you want to do is turn on one circuit for a minute and then turn on another for a minute.
    The circuits are all ready built and working. I will assume they are separate and if power is applied they will run. Why do you want the LDRs connected to the timing PIC?
    Have the power of a tracking circuit driven by a relay or MOSFET/transistor.
    Now you have two pins as out puts from the timing PIC. One for each tracker.
    When a PIC pin is set either HIGH or LOW it will stay that way until it is changed.
    Try it with an LED.
    START:
    HIGH PORT?.?  ' A Tracker POWER
    LOW PORT?.?  ' B Tracker POWER
    PAUSE 60000
    LOW PORT?.?  ' A Tracker
    HIGH PORT?.?  ' B Tracker
    PAUSE 60000
    GOTO START
    I know...I am missing something.
    I think he wants to switch the circuit he has from 1 motor to the other so as not to buy / build another tracking circuit. It is doable but the issue I see is when switching from 1 set of sensors to another the calibration difference may throw things out of whack. I think all you need is a simple loop to switch a relay, something like:
    loop:
    PortB.0 = 0
    pause 60000
    portb.0 = 1
    pause 60000
    goto loop
    EDIT: Another issue came to mind, and that is how your tracking circuit will react to having its outputs go from open circuit to loaded
    being switched by a relay, I am thinking some big resistors (high watt high ohm value) joining those circuits to handle the transients, or perhaps MOVs. Better yet use FETs to switch instead of relays . Damn I must be getting old . . .
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 09:41
