Toggled Pic flip flop Help Please
Results 1 to 3 of 3
    Oct 2007
    Default Toggled Pic flip flop Help Please
    Hi all
    I have had a bit of a blonde moment and wonder if anyone could help me,
    Thanks...
    Can anyone suggest a small bit of self contained code I can add at the end of my existing code, That will give me a toggled flip-flop output.
    EG, gp0 i/p (triggered high to low via push button)
    gp1 o/p (low at switch on)
    gp2 o/p (high at switch on)
    When i/p triggered the o/p's swap over and latch in that state until the button is pressed again, after it will then return back to the original state.
    Also how difficult is it to get the pic to remember its last state after a power up/down
    This is a test program I tried to get working, before modding and inserting into my existing code.
    ' Define Hardware
    InputTrigger var GPIO.2 ' Input normally HIGH, goes LOW to Trigger
    OutputLine0 var GPIO.0 ' Normally LOW, goes HIGH when triggered
    OutputLine1 var GPIO.1 ' Normally LOW, goes HIGH when triggered
    ' Initialise PIC
    Reset:
    TRISIO=%00000100 ' Preset I/O
    CMCON=%00000111 ' Disable Comparators
    ANSEL=%00000000 ' Disable ADC
    pause 200
    HIGH OutputLine0 ' Set output
    LOW outputline1 ' Set output
    if outputline0=0 then outputline1=1 (these are the two lines i am having)
    if outputline0=1 then ouputline1=0 ( problems with )
    ' Main Program Loop
    Loop:
    ' Test for Trigger
    If InputTrigger=0 then ' Test for Trigger
    toggle OutputLine0 ' Enable Output
    Goto Loop
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I am not sure why you have these two lines – they will always be false since they follow your HIGH and LOW statements ... delete them (in my opinion)
    To get you going, try this for your Loop – Goto Loop section (written close to your style).
    Loop:
    'Test for Trigger
    	pause 30				' Debounce time
    	If InputTrigger = 1 then Loop	' Debounce check – exit out of loop if not low after 30 mS
    	While InputTrigger=0			' Wait for button release before updating
    	Wend					' so you do not race through your Loop routine a zillion times before you release the button
    	GPIO = GPIO ^ 3			' Toggle bits 0 and 1 - See PBP manual section 4.17.14
    Endif
    Goto Loop
    After this works, you can work on saving the state of the toggle in EEPROM. What PIC are you using?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Oct 2007
    Default Hi,
    Thanks for your help,
    I have transfered your code (i can see where I went wrong) (yours is a better way)
    and it works well,
    I have decided to run the switching code in a 12F675 on its own as I had run out of ports on my 16F627,
    (Just to put you in the picture the unit is part of a two way radio repeater, and the coding was to switch between to linking radios.)
    Cheers
    Dave...
  1. Flip Flop
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 13th November 2008, 21:53
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. flip flop for driving latching solenoids
    By kitcat in forum Schematics
    Last Post: - 4th February 2006, 23:34
  4. Serial Pic to Pic using HSER
    Last Post: - 12th March 2005, 00:14
  5. need hex code to make 12c509 a flip flop,
    By bruce3mn in forum General
    Last Post: - 15th November 2004, 04:23
