Program compiles and writes but can't run
Results 1 to 16 of 16
    Mar 2009
    Colorado
    Default Can't run program
    I already had the VDD PICK2 On box checked to power up the Demo board.
    I tried to compile the code sample you provided that you say runs with this Demo board and I get a error 118...Overwriting previous address contents., and a large number of Errors #113..Symbol not previously defined.
    Any other suggestions as to how to get the program to run??
    Quote Originally Posted by jellis00 View Post
    Ok, that is easy. In the PBP root directory there are files named for the PIC you are using, ending with the suffix .inc and in these files are "DEFAULT" config statements, like the one at the beginning of the code I listed. Open the 16F690.inc file located there and find the config line, The MPASM config line will say this
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    Add an ; semicolon like so
    ;__config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    and that will solve the overwrite issue, you will for evermore have to include a config line into the code you write for this chip unless you change it back. OR you might try commenting it out in my code. Let's face it, the DEFAULT configs are there so noobies can get some code to run without knowing anything about config fuses, personally I think they serve to confuse people more than help, better I say, put this information in the manual and all the books on PICs.<br>By putting the configs in your code, it becomes easy to change oscillator, and MCLRE statements etc . . .<br><br>Now as for Symbol not previously defined, 2 main causes are inaccurate choices of symbols like BOR or MCLRE and others too, and The other MAIN reason is not having selected the correct PIC in Microcode Studio, and since I KNOW this code is correct, I would say that is the problem there. I notice it gets changed sometimes (which PIC is selected ) from the last I ran it. So you need to always check that first on compile failure with symbol error.
    Mar 2009
    Colorado
    Default Program won't run
    OK, I understand about editing the include file.
    However your instructions on selecting the right PIC in MicroCode Studio confuse me....I went thru all the menus in MSC and couldn't see where to do that. Please advise how I do that in MSC.
    Mar 2009
    Colorado
    Joe S., I commented out the line in the include file per your instructions and tried to compile again and still get all the 113 errors. ?????
    Did I mention that I am using the PICBASIC PRO Demo compiler that came with the PICkit2 Starter Kit and not a production version of PICBASIC PRO Demo.....would that make a difference?
    Hmmm I don't know beans about the Demo version except you are limited as to how many lines of code it will run. Try removing the sound lines and any blank lines and try again, also try removing the code relating to unused ports, namely porta and b, or better yet try this, with the 16f690.inc file unaltered.
    LED_1 VAR BIT  ' PORT FLAG BIT
    LED_1 = 0      ' SET INITIAL VALUE
    TRISC.0 = 0 ' Make PORTC.0 an output
    IF LED_1 = 0 THEN
    LED_1=1
    LED_1 = 0
    PORTC.0 = LED_1
    PAUSE 250 ' Delay for 1 second (compiler errors with this line - I guess the command isn't right!)
    Goto Main ' Loop forever
    Mar 2009
    Colorado
    Joe S.,
    Interestingly, when I copied this code int a Workspace project I created in MPLAB with PICkit2 set as programmer and PICBASIC Pro set as language, it compiles without any errors and will program into the PIC16F690 via the PICkit2 programming interface. It work as advertised this way.
    However, if I copy the same code into MCS and try to compile it (with the PIC16F690.incl either normal or edited per you instructions) it creates all of the same 113 and 118 errors about not licking the symbols or overwriting....the original problem I observed.
    I wanted to use the MCS/PICkit2 programming environment, but if I can't get it to compile the programs I will just have to use the MPLAB environment setup to operate with PICkit2. The reason I wanted to use MCS is because of its context help feature on PICBASIC syntax. I guess I can still write programs in MCS and then copy them into a Workspace on MPLAB for programming, but this is extra steps I wanted to avoid.
    Mar 2009
    Colorado
    Joe S.,
    You didn't answer my one question in an earlier email regarding your instructions "The other MAIN reason is not having selected the correct PIC in Microcode Studio...." Since this may be causing the unrecognized symobl error, can you please tell me how to make the PIC selection in MCS? I looked thru MCS and couldn't see how to do that.
    Joe S.,
    It is funny, the program never failed to compile and load from MCS through PICKit2. That said, it did say cancelled at the bottom, until I cut and pasted it into a new page in MCS and saved it as another name, it then compiled and said success. You and I might both need to reinstall MCS. The other code example I gave you . . . Did it work for you in MCS ?
    Do you have the "compile and program" tool bar turned on?
    If not go to view and select it from the tool bar option.
    Then you should see a drop down list box with the supported chips.
