18F4431 SSPCON.5 syntax error
Results 1 to 1 of 1
    Brussels, Belgium
    Default 18F4431 SSPCON.5 syntax error
    Why would I get a syntax error with this line ?
    SSPCON.5=0
    I want to turn off the SSP module so I can use the external interrupt pins on PortC but when I compile I get a syntrax error.
    I've checked the 18FXX31 datasheet and SSPCON is the right control register and bit 5 disables the serial port and configures the pins as I/O port pins.
    Andrew
    Fixed: http://www.picbasic.co.uk/forum/showthread.php?t=7920
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
