suggest optimize code
Results 1 to 7 of 7
    Mar 2009
    Default suggest optimize code
    helllo
    if someone have a suggestion to optimize this code pleasa reply to this thread!!
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 20/02/2009                                        *
    '*  Notes   : sms controler nokia 6210 i pic 16F887             *
    'pic defines
    	@ DEVICE pic16F887, WDT_OFF        ' Watchdog Timer
    	@ DEVICE pic16F887, PWRT_ON        ' Power-On Timer
    	@ DEVICE pic16F887, MCLR_ON        ' Master Clear Options (Internal)
    	@ DEVICE pic16F887, BOD_ON         ' Brown-Out Detect
    	@ DEVICE pic16F887, LVP_OFF        ' Low-Voltage Programming
    	@ DEVICE pic16F887, CPD_OFF        ' Data Memory Code Protect
    	@ DEVICE pic16F887, PROTECT_OFF    ' Program Code Protection
    'konfigurisi AN pinove kao digital I/O
    ansel=$00
    anselh=$00
    ' Definisanje hser-a (transmit-recive) i lcd-a u 4 bitnom modu
    define OSC 4
    DEFINE HSER_SPBRG 25
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE LCD_BITS 4
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_LINES 2
    'definisanje varijabli
    PORUKA VAR BYTE[5]
    TELBR VAR BYTE[12]
    TIME VAR BYTE [5]
    klima var byte
    J VAR BYTE
    I VAR BYTE
    ' inicijalizacija
    HIGH PORTB.7
    PAUSE 4000
    LOW PORTB.7
    ' provjeri nove poruke
    pocetak:
    HSerout ["ATZ",13,10]' pocni komunikaciju
    HSERIN 2000,pocetak,[WAIT("OK")]
         LCDoUT $FE,1,"  aktiviraj"
         LCDoUT $FE,$C0,"  uredjaj"
    textmod:
    HSerout ["AT+CMGF=1",13,10]'postavi text mod
    HSERIN 2000,textmod,[WAIT("OK")]
    mem:
    HSEROUT["AT+CPMS=",34,"SM",34,13,10]' ciljana memory lokacija
    HSERIN 2000,mem,[WAIT("OK")]
    IP:
    HSEROUT["AT+CMGL",13,10]' filter za query
        LCDOUT $FE,1,"trazi poruke.."
    HSERIN 5000,IP,[WAIT("REC UNREAD"),skip 2,str TELBR\12,skip 13,str TIME\5,skip 9,STR PORUKA\5\13]
        LCDOUT $FE,1
    I=0
    klima[1]="O"
    klima[2]="N"
    klima[3]="K"
    if poruka[i+1]=klima[i+1] and poruka[i+2]=klima[i+2]and poruka[i+3]=klima[i+3] then  gosub saljisms
    J=0
    klima[1]="O"
    klima[2]="F"
    klima[3]="F"
    klima[4]="K"
    if poruka[j+1]=klima[j+1] and poruka[j+2]=klima[j+2]and poruka[j+3]=klima[j+3] and poruka[j+4]=klima[j+4] then  gosub saljisms
    ' brisanje poruke iz memeorije
    MEM2:
    HSERIN 2000,mem2,[WAIT("OK")]
    del2:
    HSEROUT["AT+CMGD=1",13,10]
    HSERIN 2000,del2,[WAIT("OK")]
            LCDOUT $FE,1,"PORUKA ODBRISANA"
            pause 1500
    GOTO IP
    'subrutines
    'subrutina za u-i potrosca i obavjest korisnika o poduzetoj akciji
    saljisms:
    high portb.6
    HSerout ["AT",13,10]
           Pause 1000
    HSerout ["AT+CMGF=1",13,10] 'Postavi Text Mode
           Pause 1000
    HSerout ["AT+CMGS=",34,"+38761xxxxxx",34,",129",13,10]
           Pause 1000
    HSerout [str poruka,str time,10,13]
    HSerout [26]
           Pause 1000
    thx in advance
    I don't think this will work. You need to declare klima as array and not just variable.
    Also Arrays start from 0 so you have to start as klima[0] instead of klima[1].
    More, line:
    maybe compiles less with this:
    if poruka[j+0]=klima[j+0] then
        if poruka[j+1]=klima[j+1 then
             if poruka[j+2]=klima[j+2] then
                if poruka[j+3]=klima[j+3] then
                     gosub saljisms
    Mar 2009
    okay i'm going to tray it, and the next idea is:
    testmesage=1
    FOR I=0 to 3
        if poruka[i+1]<>klima[i+1] then testmesage=0
    next i
    if testmesage=1 then gosub saljisms
    poruka[0] is a blank space, so i don't need it, and i'm gona define klima as array and give it a shot!
    .......and i almost forgot!!! thx ioannis
    Mar 2009
    and next question if i put klima in eeprom using DATA command how can i call it in my program to qompare it with some other variable's?
    Why not compare array to EEPROM?
    Mar 2009
    testmesage=1
    FOR I=0 to 3
    next i
    this one works fine and compiles less....
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
