Skipping link step. Not all sources built successfully
Results 1 to 6 of 6
    Mar 2009
    Default Skipping link step. Not all sources built successfully
    Hi Everyone,
    I am using MPLAB 8.15a and PBP 8.50b and I have setup my MPLAB as in http://melabs.com/support/mplab.htm, I also looked for the failed below in the internert and I didnīt find nothing. What it is this?
    Executing: "E:\PBP\PBP.EXE" -ampasmwin -oq -z -p12F675 "BLINK.BAS"
    Skipping link step. Not all sources built successfully.
    BUILD FAILED: Mon Mar 16 13:48:03 2009
    Thanks to all
    Lightbulb
    Here is a demo compiling result window from mine:
    Executing: "C:\Program Files\Microchip\MPLAB IDE\PBP\PBPW.EXE" -ampasmwin -oq -z -p16F88 "Comm8_T14M.bas"
    PICBASIC PRO(TM) Compiler 2.50b, (c) 1998, 2008 microEngineering Labs, Inc.
    All Rights Reserved.
    Message[301] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PBP\16F88.INC 23 : MESSAGE: ( PENSEZ ā INDIQUER la BONNE CONFIG ... )
    Loaded C:\Program Files\Microchip\MPLAB IDE\Projets\Comm8_T14M.COD.
    BUILD SUCCEEDED: Mon Mar 16 18:06:50 2009
    I think you've selected the wrong Compiler ... in MPLAB menu : Project \ Select Language toolsuite.
    Mar 2009
    Hi Alain,
    I selected E:\PBP\PBP.EXE as language location and for Language Toolsuit microEngineering PicBasic Pro Compiler (pbpw.exe). So I think it is right.
    Yours looks about right to me.
    With the exception of the "W" as Alan pointed out. Double check your selection.
    Mar 2009
    You two are right, now it is working. I donīt know from where I saw that set up.
    Thank you
    Talking
    Quote Originally Posted by Jalves View Post
    Thank you
    Probably good ol' DOS running computers times ...
    Glad for you it works fine.
