Analog issue
Results 1 to 19 of 19
Thread: Analog issue
    just try
    FLASH:
    IF (Porta.4 AND NOT Porta.5) THEN
    PORTB.3 = 1
    PAUSE DUR
    PORTB.0 = 1 : PORTB.1 = 1 : PORTB.3 = 0
    GOTO MAIN
    I would replace PORTB.0 = 1 : PORTB.1 = 1 : PORTB.3 = 0 with a single write to the whole
    port to help reduce my chances of read-modify-write.
    You can make your code a lot smaller/faster also by adjusting a few simple routines.
    Below are just a few suggestions.
    PORTB = %00000111 ' setting port latches "before" tris avoids pin glitches
    TRISA = %11111111
    TRISB = %11110000
    'PORTB.0 = 1   ' done above
    'PORTB.1 = 1   ' Note: this can cause read-modify-write problems
    'PORTB.2 = 1
    'PORTB.3 = 0
    'BNK1 = 0      ' taken care of below
    'BNK2 = 0
    'DUR = 0
    MAIN:
        DUR = 0
        ' PORTB.3 = 0 ' taken care of at POR and end of Flash routine
        BNK1 = 0
        BNK2 = 0
        ADCIN 0, BNK1
        ADCIN 1, BNK2
    '    IF PORTB.4 = 1 then
    '    DUR = 8
    '    endif
    '    IF PORTB.5 = 1 THEN
    '    DUR = 4
    '    endif
    '    IF PORTB.6 = 1 THEN
    '    DUR = 2
    '    endif
    '    IF PORTB.7 = 1 THEN
    '    DUR = 1
    '    endif
        ' reverse how DIP switch assigns 8,4,2,1 with
        ' IF RB7 = 1 DUR = 8
        ' IF RB6 = 1 DUR = 4
        ' IF RB5 = 1 DUR = 2
        ' IF RB4 = 1 DUR = 1
        ' now just shift upper 4-bits read from DIP switch
        ' AND make sure upper 4-bits of result in DUR are clear.
         DUR = (PORTB >> 4) & $0F
        ' returns 8, 4, 2 or 1 in DUR if "ONLY 1" of RB7, RB6, RB5 or RB4 are set.
        IF (BNK1 => 466) OR (BNK2 => 466) THEN FLASH
        goto MAIN
    FLASH:
        IF (PORTA.4=1) OR (PORTA.5=0) THEN
    '   PORTB.0 = 0 : PORTB.1 = 0 : PORTB.3 = 1
        PORTB = %00001100 ' avoids read-modify-write
    '    IF DUR = 1 THEN
    '    PAUSE 1
    '    endif
    '    IF DUR = 2 THEN
    '    PAUSE 2
    '    endif
    '    IF DUR = 4 THEN
    '    PAUSE 4
    '    endif
    '    IF DUR = 8 THEN
    '    PAUSE 8
    '    endif
        PAUSE DUR ' DUR already holds the PAUSE time. This saves a lot of code.
    '   PORTB.0 = 1 : PORTB.1 = 1 : PORTB.3 = 0
        PORTB = %00000111 ' avoids read-modify-write
        GOTO MAIN
    I don't know which PIC you're using, but I would also check to make sure RA4 and RA5 are
    both set to digital "analog disabled" for these pins so they don't return the wrong value
    when being tested.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2004
    Michigan, USA
    Bruce, thanks for the awesome post. I feel edumacated now!
    Actually before I saw your post I changed a few things and got the board working perfectly. I'll include your port setting changes to remoe the potential RMW errors. Thanks for that suggestion.
    However, I am unable to implement the reversal of dip swith settings as the board is laid out and silkscreen shows 1, 2, 4 and 8mS.
    So, has anyone ever seen 6 LED's pulling over 1.5KW?!
    Talking Bad an excuse !!!
    Hi, JM
    May be you could have a look to manual $ 4.17.11
    REV command ...
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
