Analog issue
Results 1 to 19 of 19
Thread: Analog issue
    Feb 2004
    Michigan, USA
    Default Analog issue
    Thought I'd figured this stuff out years ago. Anyway, here's a little program to read the voltage on a bank of capacitors and fire a pair of FETs for a period of time depending on the 1's an 0's on 4 pins.
    It should not allow the FETS to fire untill the adc reading is 466 or higher. However it fires regardless of adc reading.
    What gotcha did I miss?
    18F1320, running on 8mhz internal osc.
    OSCCON = $70 'set internal resonator to 8mhz
    Define  ADC_BITS        10     	' Set number of bits in result
    Define  ADC_CLOCK       3     	' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    50    	' Set sampling time in uS
    DEFINE OSC 8
    BNK1 VAR WORD
    BNK2 VAR WORD
    DUR VAR WORD
    ADCON0 = %00000001
    ADCON1 = %01111100
    ADCON2 = %10111111
    TRISA = %11111111
    TRISB = %11110000
    PORTB.0 = 1
    PORTB.1 = 1
    PORTB.2 = 1
    PORTB.3 = 0
    BNK1 = 0
    BNK2 = 0
    DUR = 0
    MAIN:
    DUR = 0
    PORTB.3 = 0
    BNK1 = 0
    BNK2 = 0
    ADCIN 0, BNK1
    ADCIN 1, BNK2
    IF PORTB.4 = 1 THEN DUR = 8
    IF PORTB.5 = 1 THEN DUR = 4
    IF PORTB.6 = 1 THEN DUR = 2
    IF PORTB.7 = 1 THEN DUR = 1
    IF BNK1 OR BNK2 => 466 THEN FLASH
    IF BNK1 OR BNK2 =< 465 THEN MAIN
    FLASH:
    IF PORTA.4 = 1 OR PORTA.5 = 0 THEN PORTB.3 = 1
    IF PORTA.4 = 1 OR PORTA.5 = 0 THEN PORTB.0 = 0 : PORTB.1 = 0
    PORTB.3 = 0
    IF DUR = 1 THEN PAUSE 1
    IF DUR = 2 THEN PAUSE 2
    IF DUR = 4 THEN PAUSE 4
    IF DUR = 8 THEN PAUSE 8
    PORTB.0 = 1 : PORTB.1 = 1
    PAUSE 100
    GOTO MAIN
    Mar 2009
    Florida USA
    Question
    where are your ENDIF's
    Feb 2004
    Michigan, USA
    I had end if's in there and it threw errors. Deleted and compiled fine.
    Mar 2009
    Florida USA
    harr... That was the first what poked into my eye. When I copied your code into my editor (Microcode Studio), it did not compile (picbasic pro) and several error messages popped up.
    What software are you using to edit, compile etc.?
    Quote Originally Posted by jmgelba View Post
    Perhaps changing ...
    ... to ...
    IF (BNK1 => 466) OR (BNK2 => 466) THEN FLASH
    GOTO MAIN
    Feb 2004
    Michigan, USA
    DT - Thanks, that fixed the issue.
    Now, an unexpected one has appeared. First I'll explain the product.
    We are looking for a 1 to 2ms pulse appearing on either porta.0 or porta.1. Upon receipt of the pulse I have to send out a 1, 2, 4 or 8ms pulse to turn on 2 FETs located at portb.0 and portb.1 The time of the pulse depends upon dipswitch settings.
    So if set to 4ms, the program should scan the capacitors for the correct voltage, wait for a pulse input, fire FET's for 4ms when received, go back and wait for the next pulse in.
    The problem is the FETS fire anywhere from 1 time to 6 times per one 1 ms pulse input.
    I need an ultra fast reaction time so after a pulse is recieved I cant go and do other stuff before turning on the FET's.
    I thought about adding a 10ms delay at the end of the flash subroutine and I've thought about adding a count. If count = 1 and there is a pulse received, I could tell it to ignore the input. The count would have to get to reset to zero in the loop somewhere.
    Heres the code as it stands right now.
    Define  ADC_CLOCK       5     	' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    20    	' Set sampling time in uS
    DEFINE OSC 8
    BNK1 VAR WORD
    BNK2 VAR WORD
    DUR VAR WORD
    ADCON0 = %00000001
    ADCON1 = %01111100
    ADCON2 = %10111110
    TRISA = %11111111
    TRISB = %11110000
    PORTB.0 = 1
    PORTB.1 = 1
    PORTB.2 = 1
    PORTB.3 = 0
    BNK1 = 0
    BNK2 = 0
    DUR = 0
    MAIN:
    DUR = 0
    PORTB.3 = 0
    BNK1 = 0
    BNK2 = 0
    ADCIN 0, BNK1
    ADCIN 1, BNK2
    IF PORTB.4 = 1 then
    DUR = 8
    IF PORTB.5 = 1 THEN
    DUR = 4
    IF PORTB.6 = 1 THEN
    DUR = 2
    IF PORTB.7 = 1 THEN
    DUR = 1
    goto MAIN
    FLASH:
    PORTB.0 = 0 : PORTB.1 = 0 : PORTB.3 = 1
    IF DUR = 1 THEN
    PAUSE 1
    IF DUR = 2 THEN
    PAUSE 2
    IF DUR = 4 THEN
    PAUSE 4
    IF DUR = 8 THEN
    PAUSE 8
    PORTB.0 = 1 : PORTB.1 = 1 : PORTB.3 = 0
    GOTO MAIN
    Question
    Hi, JM
    That looks to be dealing with high voltage ... and very high instant currents.
    May be also a switching up converter to think to ...
    soooo ...
    are you REALLY sure there's no spike on either an ADC input or 5v supply rails ???
    could we have a piece of scheme showing the Fet's drive and the ADC inputs ???
    Feb 2004
    Michigan, USA
    There could be spikes - I have yet to measure for that. And yes, we are switching 2 channels, both at 760W each. 24v at 31.6 Amps.
    I'd have to ask the whole forum to sign an NDA to show you the schematic, but the 5v line has a lot of capacitance but the inputs do not as I cant wait for the line to charge. From input pulse to output on needs to be less than 35uS. My customer wanted 5uS or less originally!!
    Make it so . . http://www.realmagicwands.com/
    Feb 2004
    Michigan, USA
    Just measured for spikes - there are some small ones on the 5v line lasting in the uS range. Largest I've seen was 0.341V. ADC line is dirty. I'm sampling for 20uS. I'll put a .1uF and a 1nF on there and see what happens.
    I put a 10ms delay at the end of the flash subroutine and so far that looks to be working.
    Wink
    One thing you easily can do is lock your inputs as soon as Fets fired ... you have the time the capacitors charge for gliches " hiding" ...
    I'll search on my HDD ... there's an old Elektor project of a ... discharge capacitor welding machine for NiCads ...
    Your application HardW should not be so far from that !!!
    Feb 2004
    Michigan, USA
    Hmm have a problem else where. Just to verify my 10ms delay was working, I increased it to 1000ms. Now the flash (FET's)does not respond to the input. I can send a pulse and nothing happens, then I get lucky some times. Turns out that the program is running and pausing for 1000ms as though there has been a pulse sent.
    So the problem I have is it is running through the whole program and not returning to MAIN and waiting for a pulse.
    goto MAIN
    This should make the program jump back to the start of MAIN unless the ADC is 466 or higher, right?
    FLASH:
    IF DUR = 1 THEN
    PAUSE 1
    IF DUR = 2 THEN
    PAUSE 2
    IF DUR = 4 THEN
    PAUSE 4
    IF DUR = 8 THEN
    PAUSE 8
    PAUSE 1000
    GOTO MAIN
    the program is running the FLASH routine without actually sending a pulse out to the FETs unless one of the inputs is triggered. I know this because I can measure the time delay between applying an input signal and waiting for an output.
    So my question is, why is there up to a 1 second delay between applying a signal and getting an output?
    Feb 2004
    Michigan, USA
    Nevermind - I see it. The flash routine will only fire the FETS if there is an input, it will still run the routine if there is an input or not. OK, so, how do I get it to go back to the start of the program if there is no input rather than go through the whole flash routine and wait that 1000mS?
    Got it !!!
    I only can pass the program ( AT Tiny ...) but it can give you some ideas.
    the article with scheme ( nothing special ) is 400 kb ..
    But you can retrieve it from the english Elektor site. ( year is 2006 )
    Feb 2004
    Michigan, USA
    Thanks for the zip!
    OK, getting there. Here is the code at the moment.
    DEFINE OSC 8
    BNK1 VAR WORD
    BNK2 VAR WORD
    DUR VAR WORD
    ADCON0 = %00000001
    ADCON1 = %01111100
    ADCON2 = %10111110
    TRISA = %11111111
    TRISB = %11110000
    PORTB.0 = 1
    PORTB.1 = 1
    PORTB.2 = 1
    PORTB.3 = 0
    BNK1 = 0
    BNK2 = 0
    DUR = 0
    MAIN:
    DUR = 0
    PORTB.3 = 0
    BNK1 = 0
    BNK2 = 0
    ADCIN 0, BNK1
    ADCIN 1, BNK2
    IF PORTB.4 = 1 then
    DUR = 8
    IF PORTB.5 = 1 THEN
    DUR = 4
    IF PORTB.6 = 1 THEN
    DUR = 2
    IF PORTB.7 = 1 THEN
    DUR = 1
    goto MAIN
    FLASH:
    if PORTA.4 = 0 or PORTA.5 = 1 THEN
    GOTO MAIN
    IF PORTA.4 = 1 or PORTA.5 = 0 THEN
    IF DUR = 1 THEN
    PAUSE 1
    IF DUR = 2 THEN
    PAUSE 2
    IF DUR = 4 THEN
    PAUSE 4
    IF DUR = 8 THEN
    PAUSE 8
    GOTO MAIN
    The problem is with the inputs. It will not fire the outputs unless PORTA.4 = 1 AND PORTA.5 = 0
    I need this to be OR just like it is in the code. Program works perfectly if I have both inputs connected, but I need to be able to fire if there is a 1 on A.4 or if there is a 0 on A.5
    Thats my last issue.
    just try
    FLASH:
    IF (Porta.4 AND NOT Porta.5) THEN
    PORTB.3 = 1
    PAUSE DUR
    GOTO MAIN
    I would replace PORTB.0 = 1 : PORTB.1 = 1 : PORTB.3 = 0 with a single write to the whole
    port to help reduce my chances of read-modify-write.
    You can make your code a lot smaller/faster also by adjusting a few simple routines.
    Below are just a few suggestions.
    PORTB = %00000111 ' setting port latches "before" tris avoids pin glitches
    TRISA = %11111111
    TRISB = %11110000
    'PORTB.0 = 1   ' done above
    'PORTB.1 = 1   ' Note: this can cause read-modify-write problems
    'PORTB.2 = 1
    'PORTB.3 = 0
    'BNK1 = 0      ' taken care of below
    'BNK2 = 0
    'DUR = 0
    MAIN:
        DUR = 0
        ' PORTB.3 = 0 ' taken care of at POR and end of Flash routine
        BNK1 = 0
        BNK2 = 0
        ADCIN 0, BNK1
        ADCIN 1, BNK2
    '    IF PORTB.4 = 1 then
    '    DUR = 8
    '    endif
    '    IF PORTB.5 = 1 THEN
    '    DUR = 4
    '    endif
    '    IF PORTB.6 = 1 THEN
    '    DUR = 2
    '    endif
    '    IF PORTB.7 = 1 THEN
    '    DUR = 1
    '    endif
        ' reverse how DIP switch assigns 8,4,2,1 with
        ' IF RB7 = 1 DUR = 8
        ' IF RB6 = 1 DUR = 4
        ' IF RB5 = 1 DUR = 2
        ' IF RB4 = 1 DUR = 1
        ' now just shift upper 4-bits read from DIP switch
        ' AND make sure upper 4-bits of result in DUR are clear.
         DUR = (PORTB >> 4) & $0F
        ' returns 8, 4, 2 or 1 in DUR if "ONLY 1" of RB7, RB6, RB5 or RB4 are set.
        goto MAIN
    FLASH:
        IF (PORTA.4=1) OR (PORTA.5=0) THEN
    '   PORTB.0 = 0 : PORTB.1 = 0 : PORTB.3 = 1
        PORTB = %00001100 ' avoids read-modify-write
    '    IF DUR = 1 THEN
    '    PAUSE 1
    '    endif
    '    IF DUR = 2 THEN
    '    PAUSE 2
    '    endif
    '    IF DUR = 4 THEN
    '    PAUSE 4
    '    endif
    '    IF DUR = 8 THEN
    '    PAUSE 8
    '    endif
        PAUSE DUR ' DUR already holds the PAUSE time. This saves a lot of code.
    '   PORTB.0 = 1 : PORTB.1 = 1 : PORTB.3 = 0
        PORTB = %00000111 ' avoids read-modify-write
        GOTO MAIN
    I don't know which PIC you're using, but I would also check to make sure RA4 and RA5 are
    both set to digital "analog disabled" for these pins so they don't return the wrong value
    when being tested.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2004
    Michigan, USA
    Bruce, thanks for the awesome post. I feel edumacated now!
    Actually before I saw your post I changed a few things and got the board working perfectly. I'll include your port setting changes to remoe the potential RMW errors. Thanks for that suggestion.
    However, I am unable to implement the reversal of dip swith settings as the board is laid out and silkscreen shows 1, 2, 4 and 8mS.
    So, has anyone ever seen 6 LED's pulling over 1.5KW?!
    Talking Bad an excuse !!!
    Hi, JM
    May be you could have a look to manual $ 4.17.11
    REV command ...
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
