Weird code problem
Results 1 to 6 of 6
    Aug 2007
    Mississauga, Ontario, Canada
    Thank you for the reply Bruce...
    EncodedData var word [4] should be EncodedData var word [5]
    You mean you can't use a zero for an array pointer?
    2 bytes are needed for each byte conversion to manchester.
    Right... and I thought the conversion routine did just that. Am I missing anything besides the improper definition of the EncodedData array?
    With EncodedData var word [4] you have 4 words total in the array.
    EncodedData[0]
    EncodedData[1]
    EncodedData[2]
    EncodedData[3]
    Now with;
    mydata [0]= "T"
    mydata [1]= "E"
    mydata [2]= "S"
    mydata [3]= "T"
    mydata [4]= "."
    If each byte in mydata gets encoded as 2 bytes, you're going to need more
    than 4 words or 8 bytes to store your encoded data in.
    So, when mydatactr is 4, and you jump to your encode routine;
    encodeddata.lowbyte[mydatactr]=manchesterword.lowbyte
    encodeddata.highbyte[mydatactr]=manchesterword.highbyte
    It's placing the encoded value outside your EncodedData word array. I.E. you
    now have two bytes of data in RAM out-of-bounds of your array.
    You can, but you need to make sure you don't exceed the array boundary.
    A 4 word array only goes from 0 to 3. Not 0 to 4.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2007
    I see... I had incorrectly assumed it goes from 0 to 4. Duly noted.
    I will give it a try and report back...
    thank you for the pointers...
    Alex
    Aug 2007
    Talking
    Bruce...
    that did it! The transmitter now spits out good data.
    In addition to the increase in the array size, I also had to make the following change from:
    To:
    EncodedDataLow var Byte [5]
    EncodedDataHigh var byte [5]
    For some reason the splitting the manchester word into EcodedData.LowByte and EncodedData.Highbyte didn't quite work, and so I ended up creating sepatate bytes for the high and low ends of the manchester word.
    Not sure why it didn't work in the first place but it doesn't matter now. I might revisit this issue at a later date.
    Thank you for steering me in the right direction. This would have never crossed my mind - must be a habit from my old QBasic programming days.
    Alex
  1. Problem compiling EasyHID code
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 21:46
  2. MN1307 sample code problem
    Last Post: - 20th November 2008, 21:41
  3. Making Program Code Space your playground...
  4. PIC18F got some weird problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 17:18
  5. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 04:30
